| New Reply |
Calculating the uncertainty in an A4 page |
Share Thread |
| Sep20-12, 03:30 PM | #1 |
Calculate the uncertainty in the area of an A4 page using a 30cm ruler with mm divisions. 2. Relevant equations 3. The attempt at a solution Page is measured as: Height H = 297mm Width W = 210mm H x W = 62370 mm^2 I'm using this formula to calculate the area uncertainty: (dA/A)^2 = (dH/H)^2 + (dW/W)^2 (0.5/297)^2 + (0.5/210)^2 = (dA/62370)^2 (0.000002834 + 0.000005669)^0.5 = dA/62370 (0.000008503)^0.5 = dA/62370 0.002916 = dA/62370 dA = 181.87 So the area is: 62370 +/- 180 mm^2 Have I done this correctly? Thank you. |
| Sep20-12, 04:12 PM | #2 |
You could have simplified your calculation if you observed that ## (\frac {dH} {H})^2 + (\frac {dW} {W})^2 = (\frac {dA} {A})^2 = (\frac {dA} {HW})^2 ##, so you can multiply the equation by ##(HW)^2 ##, getting ## W^2dH^2 + H^2dW^2 = dA^2 ##. This has a very simple geometric interpretation, as ##WdH ## and ## HdW ## are the areas of rectangular margins at the sides of the paper during to uncertainty. Further noting that ## dH = dW = dx = 0.5 ##, you get ## dA = dx \sqrt {H^2 + W^2} ##.
| New Reply |
Similar discussions for: Calculating the uncertainty in an A4 page
| Please help calculating the uncertainty here | Introductory Physics Homework | 1 | ||
| Help calculating uncertainty of slope & intercept of cal. curves. uncertainty ?s | Biology, Chemistry & Other Homework | 2 | ||
| Calculating with Uncertainty | Introductory Physics Homework | 1 | ||
| calculating uncertainty | Introductory Physics Homework | 4 | ||
| calculating uncertainty | Introductory Physics Homework | 3 | ||
