Calculating Mass of Calcium in Saturated Water Tank
The discussion focuses on calculating the mass of calcium ions dissolved in a 40.0-gallon hot-water tank saturated with calcium phosphate, using the solubility product constant (Ksp) of calcium phosphate, which is 2.0e-29. The correct dissolution reaction is Ca3(PO4)2 (s) ⇌ 3Ca2+ (aq) + 2PO43- (aq). The participants emphasize the importance of balancing the chemical equation and using the Ksp expression to find the concentration of calcium ions in the solution, ultimately leading to the calculation of the mass of calcium ions present.
  • Understanding of solubility product constant (Ksp)
  • Knowledge of chemical equilibrium and balanced chemical equations
  • Ability to perform unit conversions (gallons to liters)
  • Familiarity with molar mass calculations
  • Study the concept of solubility product constants in detail
  • Learn how to balance complex chemical equations
  • Explore calculations involving molar mass and conversions
  • Investigate the implications of saturation in chemical solutions
Chemistry students, educators, and professionals involved in chemical analysis and solubility calculations will benefit from this discussion.
Kawrae
I know this isn't a physics problem, but it's due tomorrow and I'm really stuck :(
Calculate the mass, in grams, of calcium ion dissolved in the water of a 40.0 gallon hot-water tank saturated with calcium phosphate. (Ksp calcium phosphate = 2.0e-29, 1.00gal=3.80L).
>> I'm really lost here, we just started Ksp at the end of last class and I'm stuck. So far I just converted 40.0gal = 152L. I also *think* Ksp = [Ca][PO4]? Do I have to set up an equilibrium table? Actually, I'm not even sure of the chemical equation to set up... Ca3(PO4)2 <-> Ca2+ + (PO4)3- ??
:( Please help I'm very confused!
Your equation : [tex]Ca_3(PO_4)_2 \leftrightarrow nCa^{2+} + m(PO_4)^{3-}[/tex] needs to be balanced. That is the first step.
Then you must write [tex]K_{sp} = [Ca^{2+}]^n[(PO_4)^{3-}]^m[/tex]
If there's x moles/L of calcium ions, how many moles/L of phosphate ions will you have ? Use the balanced equation to determine this.
Plug these numbers into the equation (above) for Ksp and solve for x.
From here it's fairly straightforward.
Hey there, I understand that you are stuck on this problem and are feeling overwhelmed. First of all, take a deep breath and try not to panic. Let's break down the problem step by step to make it more manageable.
Step 1: Write out the chemical equation for the dissolution of calcium phosphate in water. It is correct that the Ksp expression for calcium phosphate is [Ca2+][PO43-], but the chemical equation for this reaction is actually Ca3(PO4)2 (s) ⇌ 3Ca2+ (aq) + 2PO43- (aq). This means that for every one mole of calcium phosphate that dissolves, 3 moles of calcium ions and 2 moles of phosphate ions are produced.
Step 2: Convert the volume of the tank from gallons to liters. You have correctly converted 40.0 gallons to 152 liters.
Step 3: Calculate the moles of calcium phosphate present in the tank. To do this, we need to use the molar volume of water, which is 18.02 L/mol at room temperature and pressure. This means that 152 L of water is equivalent to 152/18.02 = 8.43 moles of water. Since calcium phosphate has a molar mass of 310.18 g/mol, we can calculate the moles of calcium phosphate present in the tank by multiplying the molar volume of water by the molar mass of calcium phosphate: 8.43 moles x 310.18 g/mol = 2614.04 g.
Step 4: Use the Ksp expression to calculate the concentration of calcium ions in the saturated solution. We know that the Ksp for calcium phosphate is 2.0 x 10^-29, so we can set up the following equation: 2.0 x 10^-29 = [Ca2+]^3[PO43-]^2. Since the solution is saturated, we can assume that all of the calcium phosphate has dissolved, so the concentration of calcium ions is equal to the concentration of phosphate ions. Therefore, we can rewrite the equation as 2.0 x 10^-29 = [Ca2+]^3[Ca2+]^2 = [Ca2+]^5. Solving for [Ca2+], we get [Ca2+] = (2.0 x 10^-29)^1/5 = 1.
13K
  • · Replies 19 ·
15K
