Need help on magnetic fields and free space
The discussion focuses on calculating the magnetic field generated by a long straight wire with a right-angle bend. The correct formula for the magnetic field at a specific point involves the Biot-Savart Law, which accounts for both the straight and curved sections of the wire. The initial assumption that the fields from the straight sections cancel each other is incorrect; they actually contribute to the magnetic field in the same direction. The final magnetic field expression is derived from the contributions of both the straight and curved segments of the wire.
  • Understanding of magnetic fields and current-carrying conductors
  • Familiarity with the Biot-Savart Law
  • Knowledge of the right-hand grip rule for magnetic field direction
  • Basic concepts of permeability of free space
  • Study the Biot-Savart Law in detail to understand its application in various geometries
  • Learn how to apply the right-hand grip rule in different current configurations
  • Explore the concept of magnetic fields due to multiple current-carrying wires
  • Investigate the effects of different wire shapes on magnetic field calculations
Students and professionals in physics, electrical engineering, and anyone involved in electromagnetic theory or applications related to current-carrying conductors.
andrew410
A very long straight wire carries current I. In the middle of the wire a right-angle bend is made. The bend forms an arc of a circle of radius r as shown in the figure below.
Figure: http://east.ilrn.com/graphing/bca/user/appletImage?dbid=1161207397
Lets say the permeability of free space is mu. So I believe the answer is ((mu*I)/(4*pi*r))*(pi/2), which equals to (mu*I)/(8*r).
It says the answer is wrong... Can anyone help?
what are you asked to solve? The magnetic field at the dot?
I'm assuming you want to find the magnetic field where the black dot is in the diagram. Working out the field due to the straights part of the wire is easy, it is as if there's one infinitely long wire carrying current I and distance r from the point where you want to find the B field. Working out the magnetic field due to the curved part of the wire is a tiny bit trickier, you need to use Biot Savart Law (give it a go). Finally you need to add the resultant B fields due to the straight & curved parts of the wire.
Edit: I noticed your answer is correct only for the curved part of the wire, and I'm assuming you thought that the two straight parts canceled out with each other, right? Well they don't. Use the right hand grip rule to see that they both produce a field in the same direction.
16K
