Imposing boundary conditions on a string
The discussion revolves around the physical implementation of boundary conditions for a differential equation representing a string under a force. Participants explore various scenarios for fixing the slope of the string at one end, considering both static and dynamic conditions.
  • One participant suggests that to impose a boundary condition of y'(0) = a, one might consider angling a pole, but expresses concern about the string not being attached at x=0.
  • Another participant argues that the end point at x=0 would oscillate, implying that y'(0) = 0 could mean a fixed amplitude rather than a fixed slope.
  • A participant clarifies that the entire string is acted upon by a force f(x) and emphasizes the need to fix the slope at x=0 without time dependence in the problem.
  • One participant challenges the exclusion of time, stating that the shape of the string must vary over time due to the nature of force.
  • Another participant insists that the force does not vary with time and that the string reaches a fixed shape y(x) based on equilibrium.
  • There is a discussion about the concept of a "snapshot" of the string's shape at a moment in time, with a focus on balancing forces rather than time evolution.
  • One participant proposes solving a partial differential equation with specified initial and boundary conditions to explore the problem further.
  • Another participant points out that the scenario described is not a wave problem but rather a string under a force, referencing the catenary curve for a string hanging under gravity.
  • There is a suggestion that the motion of the string could be oscillatory, leading to mechanical waves, but this is contested by others who question the relevance of oscillation to the original problem.
Participants express differing views on the necessity of time dependence in the problem, the nature of the forces acting on the string, and the implications of boundary conditions. No consensus is reached on these points.
Limitations include the unclear assumptions regarding the nature of the forces and the specific conditions under which the boundary conditions are applied. The discussion also reflects varying interpretations of the role of time in the behavior of the string.
painfive
I need to know how different boundary conditions on the DE representing a string under a force can be physically implemented. For example, if you need y(0)= 0, just tie the string to y=0 at that end. If you need y'(0)=0, attatch it so that it can freely slide up and down a pole at x=0. But what if you need y'(0) = a, some constant? I was thinking you could put the pole at an angle, but then the string wouldn't always be attatched at x=0. How could you do it?
The end would be oscillating.The amplitude of the point 'x=0' will change with time under the influence of an external factor...And that will send the string into a prescribed oscilating movement...
So the description of y'(0)=0 means the the point 'x=0' will have a fixed amplitude,not necessarily 0...
Daniel.
I'm sorry, I should have been clearer. y(x) is the position of the string, and y'(x) is the slope. The entire string is acted on by a force f(x). I need to do something with the setup to fix a certain slope at the x=0 end, regardless of what the force applied is. There is no time in the problem.
Now that I think about it, I don't know if my idea for y'(0)=0 would work either. The string would just slide down until the vertical component of tension equaled the f(0). Now I'm completely lost.
It really doesn't make any sense what you're telling me here.The time dependence HAS TO BE INCLUDED.The concept of force itself requires that the "shape" of the string will vary in time...
So please set the initial conditions on the amplitude
[tex]y(x,t)[/tex] and the "velocity" [tex]y'_{t}(x,t)[/tex].
Daniel.
The force does not vary in time. It reaches an equilibrium with the tension and the string takes on a fixed shape y(x).
Yes,but that's a "snapshot",y=y(x) is the image of a string at a certain moment of time...But that's it...You cannot make any assumptions on it...
Daniel.
If you want to be really precise, with f(x,t) = 0 for t<0 and f(x) for t>0, it is the snapshot at t=infinity, after all transient effects have disappeared. But it isn't necessary to involve time at all, you just need to balance the forces. The DE the string must satisfy is T0 d2y/dx2 = F(x), where T0 is the original tension in the string (it's an approximation). I'm just trying to find out what you physically have to do to ensure y'(0) is some constant 'a', regardless of the force applied.
Solve the PD equation
[tex]\frac{1}{v^{2}} \frac{\partial^{2} y(x,t)}{\partial t^{2}}=\frac{\partial^{2} y(x,t)}{\partial x^{2}} +F(x)[/tex]
with the initial conditions that u want:
[tex]y(x,0)=blah,blah,... ;y'_{t}(x,0)=a[/tex]
and the boundary conditions what u like
[tex]y(0,t)=y(L,t)=0[/tex] (fixed ends).
Daniel.
It's not a wave, it's a string under a force. If f(x) was, say, g, it would be a string hanging under the influence of gravity, and the solution would be the catenary curve. And only one of the ends is fixed, the other end is supposed to have a fixed slope.
It's an oscillatory motion of string giving rise to mechanical waves...
This is of course,unless the problem is totally different.I thought you were referring to that...
In the case u describe,what is the problem...?
Daniel.
  • · Replies 22 ·
  • · Replies 19 ·
