Register to reply
Projectile Motion Problems
by pinksparkles2
Tags: motion, projectile
Share this thread:
pinksparkles2
#1
Sep26-12, 05:30 PM
P: 8
1. A soccer ball is kicked so that it has a range of 30m and reaches a maximum height of 12m. What velocity (magnitude and direction) did the ball have as it left the footballer's foot?
I used the equation to solve for time and got 1.55s. I'm not sure if air resistance is involved, we never discussed how to solve problems with air resistance in class.
2. A stone is thrown with a speed of 20.0 m/s at an angle of 48 to the horizontal from the edge of a cliff 60.0m above the surface of the sea.
(a) Calculate the velocity with which the stone hits the sea.
(b) Discuss qualitatively the effect of air resistance on your answers to (a).
3. The maximum height reached by a projectile is 20m. The direction of the velocity 1.0s after launch is 20; find the speed of launch.
Is air resistance included in all of these problems?
Phys.Org News Partner Science news on Phys.org
New model helps explain how provisions promote or reduce wildlife disease
Stress can make hard-working mongooses less likely to help in the future
Grammatical habits in written English reveal linguistic features of non-native speakers' languages
lewando
#2
Sep26-12, 05:46 PM
PF Gold
P: 1,053
For the first problem, what does 1.55s represent? Air resistance is assumed negligible.
pinksparkles2
#3
Sep26-12, 06:08 PM
P: 8
Sorry, s stands for seconds. Could you explain how to solve the problems?
lewando
#4
Sep26-12, 06:18 PM
PF Gold
P: 1,053
Sorry, I meant the interval of time, in seconds, what does that represent? Which equation did you use? Show those steps. For example of what I'm asking: does your time result represent the total flight time or the time it took to reach the highest point during flight?
pinksparkles2
#5
Sep26-12, 06:48 PM
P: 8
I think the time is how long it was in flight, I'm not sure if this is correct or if I was even supposed to solve for time. I used this equation:
Δy=Vyt + 0.5αyt^2
12=0.5(-10)(t^2) and used this to solve for t
lewando
#6
Sep26-12, 06:55 PM
PF Gold
P: 1,053
Okay, there was a term, Vyt. How did you make that disappear?
pinksparkles2
#7
Sep26-12, 06:58 PM
P: 8
Isn't the velocity of y zero? So then it would be (0)(1.55) which is zero, right?
lewando
#8
Sep26-12, 07:11 PM
PF Gold
P: 1,053
So to visualize what is going on-- along the y axis-- initially the footballer's foot gives an initial Vy0 resulting in the ball going up. At some time, the ball stops going up-- Vy = 0. This is what made Vyt disappear in your equation. You have solved for this time. Now the ball comes back down. The moment before it hits the ground, it has a non-zero velocity. Do not consider this zero velocity. By symmetry you can determine the total flight time.
pinksparkles2
#9
Sep26-12, 07:15 PM
P: 8
Ok then how do I use this to find the magnitude and direction of velocity?
lewando
#10
Sep26-12, 07:23 PM
PF Gold
P: 1,053
Now that you know the total flight time, can you determine Vx?
pinksparkles2
#11
Sep26-12, 07:41 PM
P: 8
I could use Vx=Vox+at but I don't know what Vox is.
lewando
#12
Sep26-12, 07:46 PM
PF Gold
P: 1,053
In the x direction, acceleration is 0. How about distance = rate * time?
pinksparkles2
#13
Sep26-12, 07:55 PM
P: 8
I'm not sure what that formula is, will it help me solve for velocity? These are IB questions, not sure if that makes a difference.
lewando
#14
Sep26-12, 08:00 PM
PF Gold
P: 1,053
That formula is a result of this formula with a = 0:
x - x0 = v0t+ 0.5at2
azizlwl
#15
Sep26-12, 08:05 PM
P: 963
I think should start with what you know and do not know that lead to the answer.
Knowns(3) - x and y(0 and 12m) distances.
Unknowns(3) - v0, θ, t
So you need 3 equations.
There are 3 SUVAT equations.
s=v0t + 1/2 at2
v2=u2+2as
v-u =at
In this problem we are taking up positive and acceleration a as negative.
You have 2 s(x and y) which are independent.
So you need 3rd equation. You can use the last equation(vy-uy)=at as the third equation(only in y direction with acceleration).
lewando
#16
Sep26-12, 08:15 PM
PF Gold
P: 1,053
Quote Quote by pinksparkles2 View Post
I need to check out for the night. I was going to suggest that you find Vx0 (or Vx, since ax is 0), and then Vy0. The vector sum will give you the answer.
Register to reply
Related Discussions
Projectile motion problems Introductory Physics Homework 1
Projectile motion problems Introductory Physics Homework 12
Help on projectile motion problems ? Introductory Physics Homework 4
Projectile Motion Problems Introductory Physics Homework 7
Projectile Motion problems (don't want answers to problems) Calculus & Beyond Homework 1
