Any AutoCad users? If so I have a ?
  • Thread starter Thread starter faust9
    autocad
The discussion revolves around the use of AutoCad for modeling an 8 bar parallel mechanism, specifically focusing on how to create a linked system where the rotation of one part affects others. Participants explore the capabilities of AutoCad 2005 in this context and consider alternatives for verifying clearances and demonstrating system functionality to a client.
  • The original poster seeks a method in AutoCad to create a linked system where rotating one part causes changes in other parts.
  • One participant suggests using the "Block" command to group objects, allowing for rotation as a single entity, but questions if this meets the original poster's needs.
  • Another participant interprets the request as needing a connection between blocks, such as gears, where movement in one affects the other in a related manner.
  • A different participant states that plain AutoCad lacks the functionality for dynamic analysis and suggests that the best approach would be to redraw each position individually.
  • This participant mentions an AutoCad Mechanical add-on but notes it primarily automates repetitive tasks without providing dynamic analysis capabilities.
  • The original poster clarifies the need to demonstrate input link orientation and ensure the parallel link remains parallel, while also accommodating a client with limited software resources.
  • The original poster expresses frustration with manual adjustments and reiterates the desire for a solution within AutoCad to facilitate client interactions.
Participants do not reach a consensus on the capabilities of AutoCad for the requested functionality. There are differing opinions on whether the suggested methods meet the original poster's requirements, and the discussion remains unresolved regarding the best approach to achieve the desired modeling.
The discussion highlights limitations in AutoCad 2005 for dynamic modeling and the potential need for additional software to achieve the desired functionality. There is an emphasis on the challenges of demonstrating mechanical interactions without advanced tools.
faust9
I used UG NX 1.8 and 2.0 mostly but I have to do some work in AutoCad 2005. Basically, I have an 8 bar parallel mechanism and I need to model it at a few points to verify clearances and the like. I'd prefer UG but we can't always do things the easy way now can we.
My qusetion is: Is there a way to produce a linked system in autocad where rotating one part of the system casuses appropriate changes on the other parts? Just wondering otherwise I have to seek another piece of software to help me verify my clearances in addition to drafting it in autocad.
Thanks for any and all help.
Computer science news on Phys.org
I'm not sure I understand exactly what you want... but you can create blocks, using the "Block" command. A block allows you to treat a group of objects as if they were one object. So you can essentially grab the block and rotate it in the desired manner.
Perhaps this is not what you want ?
I tihnk he means something more like two "blocks" connected by a gear or gears. Move one and you get a change in the other that is related but not identical.
Plain old AutoCad does not have what you are looking for. The best you could do is what Gokul recommended. You would have to redraw each position individually. There is an AutoCad Mechanical add on made by Autodesk, but I don't think it will do any dynamic analysis. It mostly tries to automate repetitive tasks and has a lot of built in blocks and such. Here is a link to it's site:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=4260547
Just out of curiosity, what exactly do you want to do? It really doesn't take a 3D modelling software to do a tolerance stack up or interference check. If you want to go into a bit more detail, we can probably do it the old fashioned way.
Thanks for the replies. Your right, I could do it the old fashioned pen and paper way but old fashioned means extra work for me(I already did the FEA and motion/path requirements analysis). I have to physically show the input link orientation with respect to one of the couplers (one of the couplers comes very close to the housing) as well as prove the parallel link remains parallel through the path of travel to a client; additionally, I wanted something that would allow a client with limited software resources to make changes and verify the changes will not interfear with system operation. I know the system works (already did the necessary pen and paper work) but I'd like to show the results in a form my client has access to. I don't think my client has ADAMS or the like so I was hoping AutoCad would have somethink to build simple mechanical systems. It's just such a pain moving the links manually. Again, thanks for the replies.
15K
