How to Control a Boat Rudder: Suggestions Needed
  • Thread starter Thread starter sharans
    Stuck
The discussion revolves around the control of a boat rudder for a small electrically powered boat, specifically focusing on how to actuate the rudder using the motion from the propeller. The original poster questions the necessity of a rudder and seeks suggestions for effective maneuvering, particularly for competitive scenarios involving U-turns.
  • Participants are exploring the feasibility of using propeller motion to control the rudder and discussing the implications of using twin propellers instead of a rudder. Questions about the specifics of the setup, including the power source and maneuverability requirements, are raised.
Some participants are seeking clarification on the original poster's constraints and objectives, while others are suggesting alternative approaches, such as using two motors for independent speed control. The conversation is ongoing, with multiple interpretations of the problem being explored.
The original poster mentions constraints related to the incorporation of a shaft for rudder control and expresses a need for a favorable weight-to-thrust ratio for the boat's performance in a competitive setting.
sharans
Iam faced with a problem of controlling the rudder of my
20*30*15 (cm) boat.I need to take the motion for the
rudder from the propeller motion, as a shaft cannot be
incorporated.
By the way,do i need a rudder at all to control
the direction.
PLEASE REPLY AS SOON AS POSSIBLE.
ANY RELATED SUGGESTION IS VERY MUCH APPRECIATED.ASDSSDS
You're going to have to explain what you are looking for a bit better. I don't understand what you need. You want to use the rotational motion of your propeller's drive shaft to actuate the boat's rudder?
If you have twin propellers, you could get away without having a rudder, but it would not be as effective as a rudder.
Hi Fred,
Thanks for the reply.
Iam preparing for a competition wherein i need to make this small
boat to reach the given destination in minimum time.
So i need to make it as effective as possible,especially while
encountering U turns.
I wanted to know whether there is any way by which i could
actuate the rudder or go by two propellers.
PLEASE REPLY SOON.
Am I correct in assuming that this would be electric powered? Without knowing any of the constraints or objectives you are dealing with it's tough to come up with a best idea. Will this be radio controlled? What types of maneuvers do you want/need to do?
I don't readily see a way to actuate the rudder off of the driveline to the propeller like you had mentioned (not that would be easy to do that is). The two motors came to mind immediately. You would have to have two motors and be able to vary the speeds of each independently.
If you can provide some more details we could help a bit more.
You say a shaft cannot be incorporated.
Can you elaborate on this please?
Cheers.
Basically my challenge is to have the best W/Te ratio for my
boat.
W-weight carried by the boat
Te=Ta+(d1/d2)Ta
Ta-actual time taken to reach the bank
d1-deviation from the destination point
d2-shortest distance between the banks
The boat will be electrically powered.
Actually, i didn't get the idea of using two motors of varying speeds.
Is it for the twin propellers?
Then wouldn't it become less effective without a rudder?
Could u elaborate on this please.
By the way, i was talking of the shaft system commonly used to
move the rudder.
It would be kind of u if u could suggest appropriate material for its
hull.
My ship will be loaded and then i need to take it to my destination.
HOPE TO HEAR SOON FROM U GUYS,THANKS.
  • · Replies 26 ·
  • · Replies 42 ·
16K
  • · Replies 39 ·
17K
  • · Replies 69 ·
15K
