Magnetic Force: Calculating B for 4.01A Wire
The discussion focuses on calculating the magnetic force acting on a 29.5 cm wire carrying a current of 4.01 A, oriented along the z-axis, in a magnetic field with components Bx=0.193 T, By=0.233 T, and Bz=0.263 T. The magnitude of the magnetic field is determined using the Pythagorean theorem, resulting in B = 0.371 T. The magnetic force is calculated using the formula F = I * L * B * sinθ, yielding a force of 0.585 N when θ is 90 degrees.
  • Understanding of magnetic fields and their components
  • Familiarity with the formula for electromagnetic force: F = I * L * B * sinθ
  • Knowledge of the Pythagorean theorem for calculating magnitudes
  • Basic concepts of current and wire orientation in magnetic fields
  • Explore the effects of varying current on magnetic force calculations
  • Learn about the applications of the right-hand rule in electromagnetism
  • Investigate the relationship between magnetic field strength and wire length
  • Study advanced topics in electromagnetic theory, such as Lorentz force
Physics students, electrical engineers, and anyone interested in understanding the principles of electromagnetism and magnetic force calculations.
figs
The x, y, and z components of a magnetic field are Bx=0.193 T, By=0.233 T, and Bz=0.263 T. A 29.5 cm wire is oriented along the z axis and carries a current of 4.01 A. What is the magnitude of the magnetic force that acts on this wire?
how do i calc my B
cuz i know
f=4.01A/(0.295m)(?T)(sin90)
What's the expression of the electromagnetic force...?
Daniel.
To calculate the magnitude of the magnetic force, we can use the formula F = I * L * B * sinθ, where F is the force, I is the current, L is the length of the wire, B is the magnetic field, and θ is the angle between the wire and the magnetic field.
In this case, we are given the x, y, and z components of the magnetic field, so we can use the Pythagorean theorem to find the magnitude of the magnetic field: B = √(Bx^2 + By^2 + Bz^2) = √(0.193^2 + 0.233^2 + 0.263^2) = 0.371 T.
Since the wire is oriented along the z axis, the angle between the wire and the magnetic field is 90 degrees (sin 90 = 1). Therefore, the magnitude of the magnetic force can be calculated as:
F = (4.01 A) * (0.295 m) * (0.371 T) * (1) = 0.585 N
So, the magnitude of the magnetic force acting on the wire is 0.585 N.
  • · Replies 23 ·
