Problems with FFT: Seeking Help for Senior Project
  • Thread starter Thread starter brian0918
    Fft
The discussion revolves around issues encountered while implementing a Fast Fourier Transform (FFT) for a real, even dataset as part of a senior project. The original poster reports unexpected imaginary components in the output, despite the input being real and even.
  • Participants explore the nature of the input data and its expected output characteristics, questioning the assumptions about symmetry and causality in the dataset. Some suggest using built-in FFT functions in software like MATLAB, while others discuss the implications of data arrangement and periodicity on the FFT results.
There is an ongoing exploration of the reasons behind the unexpected imaginary outputs, with participants providing insights into the relationship between the input data's symmetry and the resulting FFT characteristics. Some guidance has been offered regarding the interpretation of the data and its arrangement, but no consensus has been reached.
The original poster emphasizes the need for automation in their project, which restricts the use of certain software tools. There is also mention of potential confusion regarding the indexing of the dataset and its implications for the FFT output.
brian0918
This is part of my senior project. Please help! I'm trying to use a code to FFT a real, even set of data, but the results are not real and even as would be expected.
The code I'm using is availabe http://www.koders.com/c++/fid1C48DD8DBB45CA4B87C9A38DAFC532E793443862.aspx (and http://www.koders.com/c/fid52CE41F3A31157362D33C32AB2DBEDBBE68D78D9.aspx andhttp://www.koders.com/c/fidB64062339509A55058571EB7378153A9A2151D38.aspx?s=intl.h)
When I run RealFFT with the following 16 numbers for the Real input and nothing for the Imag input, I get these results:
Real input:
0.969647
-1.28744
0.0863155
0.19462
1.06651
0.490905
0.469052
-0.728912
-0.728912
0.469052
0.490905
1.06651
0.19462
0.0863155
-1.28744
0.969647
Real output:
2.52139
-0.37157
-2.72877
4.38382
1.74303
2.06953
0.687978
0.712455
Imag output:
1.19209e-007
0.0739102
1.13029
-2.92917
-1.74303
-3.09727
-1.66093
-3.58175
Any help? I've tried a different FFT code and the same thing happens. Help! :cry:
Is there some reason you can not use matlab, mathematica, or mathcad for their built in FFT?
Everything has to be automated and separate, so I need to use code. This FFT is just a small part of the whole code.
I did a quick FFT using Excel on your data and, short of having sign issues with the imaginary output, your numbers are exactly the same that I got.
2.521395
-0.371567052707447-7.39092820943204E-002i
-2.72876745822043-1.13029248975726i
4.38381766777983+2.92917331814368i
1.7430325+1.7430325i
2.06953109891377+3.09727216864978i
0.687977458220434+1.66092451024274i
0.712454286013861+3.58174956841178i
0.712454286013851-3.58174956841177i
0.687977458220432-1.66092451024274i
2.06953109891376-3.09727216864978i
1.7430325-1.7430325i
4.38381766777983-2.92917331814369i
-2.72876745822043+1.13029248975726i
-0.371567052707448+7.39092820943208E-002i
The data is real and even though, isn't it? So, shouldn't the result also be real and even?
Nope.
Though, IIRC, the imaginary parts can be computed from the real parts, so the real parts are all you actually need when the input is real.
It should be real only if input sequence is symmetrical around t = 0. But you assume causal sequence (with FFT), so data is shifted and phase delay is introduced, by which you get imaginary component of spectrum...
At least, that's off top of my head. Could be wrong...
So how would I go about inputting data so that it would be interpreted as being symmetrical around t=0? According to the text that created the code I used, it is even if the values at k and (N-k) are the same.
I just thought about what I wrote (I should do that BEFORE writing, right?). Well, since FFT (DFT) transform results with spectrum of periodic signal whose one period is the original sequence, it doesn't matter if the sequence is causal or not, FFT "percieves" it as periodic to + and - direction, hence the dicrete spectrum.
I've input the data in Matlab, and got the same results. Shifting the array results only in different phase frequency characteristic.
The seed of doubt in my mind is that I remember this: symmetrical real signals result in _linear_ phase characteristic, not by zero-phase...
Anyway, I'm ill and it's quite late here, so I'll try to think straight in the morning (at least, I'll try ;) )
I think you're mixing up the indicies somehow. If your data set is indexed starting at zero and it's even, it will look like:
[tex]\left[x_0, x_1, x_2, x_3, x_4, x_5, x_6, x_7, x_8, x_7, x_6, x_5, x_ 4, x_ 3, x_2, x_1\right][/tex]
In this case the output will be real assuming the input is. Your data is not of this shape, so you can't expect the nice cancellation.
  • · Replies 0 ·
