Why Is Momentum Calculated by Multiplying Mass Times Velocity?
The discussion revolves around the nature of momentum, specifically why it is calculated as the product of mass and velocity. Participants explore the theoretical underpinnings, historical context, and implications of this definition within various branches of physics, including classical mechanics, special relativity, and quantum mechanics.
  • Some participants assert that momentum is simply defined as mass times velocity, questioning if there is a deeper explanation for this relationship.
  • Others argue that while momentum is defined as mass times velocity, its significance extends beyond this definition, as evidenced by different forms of momentum in various physics contexts.
  • A participant suggests that momentum can be derived from the conservation laws observed in collisions, emphasizing its experimental basis.
  • Some contributions highlight the historical evolution of the concept of momentum, noting that it was not always recognized as mass times velocity.
  • There is mention of the action principle as a unifying concept that connects mass-velocity to momentum across different disciplines.
  • One participant points out that Newton initially considered mass times velocity to be kinetic energy, indicating a historical misunderstanding of the concept.
  • Another participant proposes that momentum is a conserved quantity resulting from the invariance of a system's Lagrangian, suggesting a more fundamental theoretical framework.
Participants express a range of views on the definition and implications of momentum, with no consensus reached on whether there is a deeper theoretical justification for the mass-velocity relationship or if it is merely a definitional construct. The discussion remains unresolved regarding the fundamental nature of momentum.
Some participants note limitations in defining momentum strictly as mass times velocity, pointing to its varied forms in different branches of physics and the historical context of its definition.
vanmaiden
Good Afternoon,
How is it that we are able to get the value of momentum from multiplying mass times the velocity of a moving body? A lot of people settle for knowing how to get momentum, but I want to know why this equation works. I understand as much calculus as calc II permits me with a bit of vector calculus and linear algebra as a fair warning on my level of the comprehension of your explanations. I thank you in advance for helping me.
Vanmaiden
is momentum not simply defined as mass * velocity?
Possibly. Is there not a reason that we know of that can explain why we can combine mass and velocity in a multiplicative fashion to yield momentum?
People identified that mass x velocity was a useful quantity. They gave this quantity the name momentum.
Actually, it took quite a while for people to realize that "mass x velocity" was the quantity they should be looking at or to call this momentum instead of a host of other names, but at core, this is a definition. It is the name we give to the thing.
Perhaps you thought there was some deeper definition of momentum?
Yeah, I thought there was. I should have asked it a different way actually. How does the mass times the velocity of an object yield the characteristic we've named momentum?
But if momentum has no meaning outside of it being mass x velocity, how is it that we have determined different forms of momentum for different branches of physics? p = mγv for SR, and momentum is an operator stated by -ih∇ in quantum mechanics. Momentum may be defined as mv in classical mechanics, but is it not more general than that?
[itex]d\mathbf{p} = \int_{t_1}^{t_2}\mathbf{F}\cdot dt[/itex]
almost seems a little more general. In which case, vanmaiden, it's easy to derive p=mv from that as well, if you feel more satisfied with that explanation. Of course, force is not a super well-defined concept in some branches of physics either...
Momentum is important because it is a quantity that is conserved in the absence of external forces.
Consider a 1-dimensional collision between unequal-mass objects. Looking at the velocities of each object both before and after collision, you can deduce experimentally that there is a conserved quantity which is proportional to mass x velocity. That quantity ended up with the name "momentum" (although historically it had many other names).
Conserved quantities are important to solving the equations of motion, to figure out what happens in a given system. As you know from 1-dimensional collisions, you start by writing down the two conservation laws: momentum, and energy. These two equations give you exactly enough information to solve for the two final velocities.
Sure. Part of what I'm trying to get at is whether vanmaiden has some more fundamental notion of momentum in mind and is wondering how that can be shown to reduce to [itex]mv[/itex] in classical physics or some such. But without an idea of what that more fundamental notion is that vanmaiden may have in mind, it's difficult for me to simplify it down to [itex]mv[/itex].
One thing that is unifying regardless of exact discipline is the notion of an action principle. There, one gets the general idea of position and mass-velocity being conjugate variables, and this is one way to identify mass-velocity as a useful quantity and to decide to give it a name (momentum). From an action principle, one can derive all the properties of momentum that are familiar, even in quantum mechanics or relativity.
Also, the fact that this quantity is conserved can be derived from Newton's Third Law of Motion.
Including the name that Newton gave it: "quantity of motion." He considered it to be a fundamental quantity, which he defined before stating his laws of motion.
Is it fair to say the equation was obtained through experimentation and not so much mathematical manipulation?
Keep in mind at one point Isaac Newton thought mass times velocity was kinetic energy.
Because mass times velocity is a conserved quantity resulting from the space translation invariance of a system's Lagrangian.
  • · Replies 21 ·
  • · Replies 29 ·
  • · Replies 29 ·
  • · Replies 35 ·
  • · Replies 27 ·
