Solving Simple Kinematics: Person Throwing Rock from 40m High
  • Thread starter Thread starter tony873004
A person throws a rock from a height of 40 meters with an initial velocity of 10 m/s. The problem can be solved in one step using the equation of motion: height = initial height + initial velocity * time + 1/2 * acceleration * time^2. By rearranging this equation and substituting the values, the time until the rock hits the ground is calculated to be approximately 4.08 seconds. This approach efficiently considers the entire motion of the rock from its initial position to its final position.
  • Understanding of kinematic equations
  • Knowledge of initial velocity and acceleration concepts
  • Familiarity with solving quadratic equations
  • Basic grasp of gravitational acceleration (9.8 m/s²)
  • Study the derivation of kinematic equations
  • Learn about projectile motion and its applications
  • Explore the concept of free fall and its mathematical modeling
  • Investigate the effects of air resistance on falling objects
Students studying physics, educators teaching kinematics, and anyone interested in understanding motion dynamics and problem-solving techniques in physics.
tony873004
A person stands on the roof of a building, 40 m high. He throws a rock directly up at 10 m/s. How long until it hits the ground?
I know how to do this in 2 steps: compute height that the rock rises to (~5 meters), then compute time for an object to free fall from 0 m/s to the ground ~45 meters below.
But isn't there a way to do it in one step?
You certainly should be able to get the formula for height as a function of time: you probably use it or some version of it to get the height the rock rises to.
It is h= -4.9t2+ 10t+ 40.
Now set h= 0 and solve for t (you will get two solutions- only one is positive).
Yes, there is a way to solve this problem in one step by using the equation of motion: height = initial height + initial velocity * time + 1/2 * acceleration * time^2. We can rearrange this equation to solve for time, which gives us the formula: time = (final height - initial height) / (initial velocity * acceleration). Plugging in the given values, we get: time = (0 - 40) / (-10 * (-9.8)) = 4.08 seconds. Therefore, it will take approximately 4.08 seconds for the rock to hit the ground. This method allows us to solve the problem in one step by considering the entire motion of the rock from its initial position to its final position.
