Calculating the Speed of a Particle After 8.59 s
  • Thread starter Thread starter the_d
    Particle Speed
The original poster presents a problem involving the motion of a particle in the xy plane, starting from the origin with specified initial velocity components and a constant acceleration in the x direction. The goal is to determine the speed of the particle after a given time interval.
  • Some participants suggest breaking down the velocity into its x and y components and using vector addition to find the speed. Others discuss the appropriateness of using the formula for final velocity and clarify the distinction between the x and y components of motion.
The discussion includes various interpretations of the velocity formula and its application to the problem. Participants have provided guidance on how to approach the calculation by considering the components separately, and there is an ongoing exploration of the correct application of the relevant equations.
There is a mention of confusion regarding the use of the velocity formula, indicating potential misunderstandings about vector components and their roles in the problem. The problem is framed within the constraints of a homework assignment, which may limit the information available for discussion.
the_d
i have a question, it is:
A particle starts from the origin at t=o with an initial velocity having an x component of 21.8 m/s and a y component of -14.1 m/s. The particle moves in the xy plane with an x componet of acceleration only, given by 4.09 m/s^2. I need to find the speed of the particle after 8.59 s.
What I did:
i was goin to use the formula V = Vo + at but that is not correct for some reason
You do not need to use that formula. Keep the components split; find the x and y components of the final velocity of the particle, then add them vectorally to find the speed. (Hint: you have the rate of acceleration and the time during which the particle is accelerated; how can you find the final velocity in the x direction?)
v = vo + at works for the x-component of velocity.
The y component of velocity is constant.
v = vx i + vy j, where i is unit vector in x-direction and j is unit vector in y-direction.
or [itex]v = \sqrt({v_x^2 + v_y^2})[/itex]
Actually, that formula is correct here. You simply need to use it as a vector formula:
[tex]\vec {v} = {\vec {v}}_0 + \vec {a} t[/tex]
This corresponds to two equations, one apiece for the x and y components:
[tex]v_x = v_{0x} + a_x t[/tex]
[tex]v_y = v_{0y} + a_y t[/tex]
You know the components of the initial velocity and the acceleration, so you can find the components of the velocity at any time t. The speed of the particle at any time is the magnitude of the velocity vector at that time, by definition.
