What is the energy of an electron in a circular orbit in the Bohr model?
The discussion revolves around the energy of an electron in a circular orbit as described by the Bohr model of the hydrogen atom. Participants are analyzing the calculations related to electric potential, kinetic energy, total energy, and ionization energy of the electron.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the relationship between electric potential and kinetic energy, questioning the reasoning behind the calculations. There is an exploration of the concept that potential energy does not equal kinetic energy in a stable orbit, and some participants suggest using conservation laws and force balance to clarify the reasoning.
Some participants have provided guidance on how to approach the problem, particularly regarding the relationship between electric force and centripetal force. There is an ongoing exploration of the calculations, with some participants questioning the division of potential energy by two and seeking clarification on this aspect.
There is a mention of the assumption that the electron is in a stable circular orbit, which influences the calculations and reasoning presented. Participants are also referencing specific values and concepts from the Bohr model and Kepler's laws in their discussions.
thisisfudd
Hi,
I finished the following problem and have gotten all the right answers, but I want to make sure my reasoning is correct.
In the Bohr model of the hydrogen atom, an electron orbits a proton (the nucleus) in a circular orbit of radius 0.53 x 10^-10 m.
(a) What is the electric potential at the electron's orbit due to the proton?
27 volts using v = k (q/r) -- this one is simple, you just use the radius, and the charge, and k. OK.
(b) What is the kinetic energy of the electron?
Change in potential energy is the opposite of change in kinetic energy. Potential energy is QV, or -2.2 x 10^-18.
(c) What is the total energy of the electron in orbit?
-2.2 x 10^-18. Same as above because when it's in the orbit all of its energy is kinetic energy.
(d) What is the ionization energy -- that is, the energy required to remove the electron from the atom and take it to r = infinity, at rest?
2.2 x 10^-18. Same but opposite because you are pulling the electron away from a charge to which it is attracted. This requires a force equal and opposite to its kinetic energy in that position.
Do these answers seem complete?
a) This seems right
b) This is not right. Try setting the electric force equal to the centripetal force. Solve for the electrons velocity and then find its kinetic energy. The number is right but you reasoning seems off. Also it is not possible to have negative kinetic energy.
c) This is not right either. Total energy should be the sum of kinetic and potential. The number is right however. The kinetic energy should be positive and the potential energy should be negative. Use the suggestion in part b or use kepler's laws.
d) This has the right idea and the right number.
Hi Davorak,
Thanks for your help. Right, sorry about that, the number for B was supposed to be positive. I was under the impression, though, that applying conservation you would have potential energy having to equal kinetic energy. Otherwise, I don't really understand how the numbers could be the same except opposite (I checked the back of the book and the answers are all right).
The numbers are right, but potential energy does not equal kinetic energy for a stable orbit. This is part of orbital theroy or kepler's laws.
The easy way to find this for yourself is to:
Setting the electric force equal to the centripetal force. Solve for the electrons velocity and then find its kinetic energy.
If you do this you will see that in fact the magitude of the kinetic energy does not equal the magnitude of the potential energy.
Edit:
Total energy = kinetic + potential
if kinetic was equal but oppsite of the potentail energy then total energy would equal zero
I forgot to mention:
Potential energy QV[tex]\neq[/tex] -2.2*10^-18.
Right, because i get 4.32 * 10^-18 when i multiply the charge of electron by the Voltage.
But if you divide it by 2, you will get 2.2*10^-18
However, i have no idea why should it be divided by two...
Yes, I have the same problem -- why is it divided by 2?
Ok.
You know.
Electric potential:
[tex] \frac{1}{4 \pi \epsilon_{0}} \frac{q}{r} = k \frac{q}{r} = 4.32 * 10^{-18} [/tex]
The problem assumes the electron takes a circular orbit around the proton.
For a stable circular orbit the electric force must equal the centripetal force.
[tex] \frac{1}{4 \pi \epsilon_{0}} \frac{q}{r^{2}} = m \frac{v^{2}}{r}[/tex]
[tex] \frac{1}{4 \pi \epsilon_{0}} \frac{q}{r} = m v^{2}[/tex]
[tex] \frac{1}{4 m \pi \epsilon_{0}} \frac{q}{r} = v^{2}[/tex]
[tex] v = sqrt{\frac{1}{4 m \pi \epsilon_{0}} \frac{q}{r}}[/tex]
kinetic energy equals[tex]\frac{1}{2}mv^{2}[/tex]. So the kinetic energy of the electron is:
[tex] E_{Ke} = \frac{1}{2} \frac{1}{4 \pi \epsilon_{0}} \frac{q}{r}[/tex]
Look familiar?
Google search on kepler's laws good history and orbital theory
http://www.google.com/search?hl=en&q=kepler's+laws&spell=1
  • · Replies 23 ·
