Register to reply
Branch cuts in complex analysis
by csnsc14320
Tags: analysis, branch, complex, cuts
Share this thread:
csnsc14320
#1
Oct3-12, 01:46 AM
P: 57
Given that the standard square root sqrt(anything) has a branch cut from (-inf,0), find the branch cuts of the following:
z+sqrt(z^2-1)
z+isqrt(1-z^2)
z+sqrt(z+1)sqrt(z-1)
2. Relevant equations
3. The attempt at a solution
I understand what branch cuts do (multivalue functions -> single value), I am just having trouble since all three of those expressions can be reduced to the same expression - I don't see why they would need different cuts? I can't really find any examples online and my book only has less than one paragraph explaining branch cuts (let alone examples).
Phys.Org News Partner Science news on Phys.org
World's largest solar boat on Greek prehistoric mission
Google searches hold key to future market crashes
Mineral magic? Common mineral capable of making and breaking bonds
clamtrox
#2
Oct3-12, 03:27 AM
P: 939
Quote Quote by csnsc14320 View Post
No they can't! That is precisely the point. Perhaps you should calculate what you get when you plug in, say, z=2 into those expressions.
csnsc14320
#3
Oct3-12, 10:43 AM
P: 57
Quote Quote by clamtrox View Post
z+sqrt(z^2-1):
2+sqrt(2^2-1) = 2+sqrt(3)
-2+sqrt((-2)^2-1) = -2+sqrt(3)
z+isqrt(1-z^2):
2+isqrt(1-2^2) = 2+isqrt(-3) = 2+sqrt(3)
-2+isqrt(1-(-2)^2) = -2+isqrt(-3) = -2+sqrt(3)
z+sqrt(z+1)sqrt(z-1):
2+sqrt(2+1)sqrt(2-1) = 2+sqrt(3)sqrt(1) = 2+sqrt(3)
-2+sqrt(-2+1)sqrt(-2-1) = 2+sqrt(-1)sqrt(-3) = -2+sqrt(3)
am I missing something?
jackmell
#4
Oct3-12, 10:46 AM
P: 1,666
z+sqrt(z^2-1)
z+isqrt(1-z^2)
It's tough. Really tough as you indicated by the lack of good information in your text about it. How about this, suppose I have a function that ISN"t a polynomial. I mean trigs, logs, other non-polynomials. Call that function G. And I tell you wherever G is zero or infinity, there is a branch-point and to make a branch-cut, I define a line from one branch-point to another. So Take:
[tex]f(z)=z+\sqrt{z^2-1}[/tex]
and I know [itex]G(z)=\sqrt{z^2-1}[/itex] is not a polynomial and that the quantity [itex]z^2-1=0[/itex] when [itex]z=\pm 1[/itex]. Therefore, from what I said above, the branch points are infinity and [itex]\pm 1[/itex]. Thus I can make branch-cuts in several ways, from -1 to infinity AND 1 to infinity, or a branch-cut from -1 to 1 or I can even make one from -1, through 1 and through to infinity. Now in this particular example, the standard way of making branch-cuts would be two ways:
(1) make a cut from -1 to 1
(2) make two cuts: one from -infty to -1 and another one from 1 to infty
Now how about this: even though that's not exactly what you might want, try and use what I said to devise branch-cuts for the other ones.
clamtrox
#5
Oct3-12, 01:09 PM
P: 939
Are you using √(-1) = i or √(-1) = -i?
csnsc14320
#6
Oct3-12, 01:40 PM
P: 57
Quote Quote by jackmell View Post
OK, so if I try to map just the square roots to the range (-inf, 0) I get:
1) [tex]z^2-1=-R[/tex] where R ranges from (0, inf).
Solving for Z yields [tex]z = \pm \sqrt{1-R}[/tex], which for R<1 gives (-1,1), and for R>1 gives (-i inf, +i inf) so I get branch cuts from (-1,1) and the imaginary axis.
2) solving [tex]1-z^2=-R[/tex] yields [tex]z = \pm \sqrt{1+R}[/tex], which gives me (-inf, -1) and (1, inf) for branch cuts.
3) Solving [tex]z+1=-R, z-1=-R[/tex] gives (-inf, -1) and (-inf, 1), but the overlap cancels(?) to just give (-1,1) as the branch cut.
jackmell
#7
Oct3-12, 03:49 PM
P: 1,666
Ok, lemme' tell you something that is a key to understanding branch-cuts: they're arbitrary. That is, you can extend them from the branch-points any way you like. Now, granted, we try and standardize it somewhat as in the case of sqrt(z) where we just arbitrarly set the cut from -infty to 0 but that's not set in stone. I could equally have it run up the imaginary axis from zero or even a stair-step pattern up to infinity. So in the case of
[tex]\sqrt{1-z^2}[/tex]
you should look at that and immediately conclude the branch points are at -1 and 1 and the branch-cuts can basically extend anyway from those points, like I said, even stair-steps going up from 1 and stairsteps going down from -1. But to make it simple, we just extend the cut from -1 to 1 (branch-point to branch-point) or depending on the application, from -infty to -1 along the real axis is one cut and 1 to +infty on the real axis as another cut with infinity being another branch-point.
However, I'm not really sure what your particular question is asking.
Register to reply
Related Discussions
Complex integration, branch cuts.. Calculus 9
[Complex Analysis] Branch cuts of the logarithm Calculus & Beyond Homework 3
Branch Cuts in the Complex Plane Calculus & Beyond Homework 1
I don't get branch cuts in the complex plane at ALL Calculus 1
Branch points and branch cuts Calculus & Beyond Homework 2
