Understanding Heat and Resistors: Explained for Non-Experts
  • Context: Undergrad
  • Thread starter Thread starter quasar987
    Heat Resistors
The discussion centers on the principles of heat dissipation in resistors, specifically through the equation P = RI², which quantifies the power loss as heat due to electrical resistance. It explains that heat is a form of energy measured in Joules and relates the process of Joule heating to the rise in temperature of a resistor when current flows through it. The analogy of electrical resistors to friction in mechanical systems is highlighted, emphasizing that energy is converted to thermal energy. Additionally, the transfer of momentum from electrons to the lattice structure of the resistor is discussed, illustrating how energy dissipates through collisions and vibrations.
  • Understanding of electrical resistance and Ohm's Law
  • Basic knowledge of thermodynamics and heat transfer
  • Familiarity with Joule heating and its implications
  • Concept of electron drift velocity in conductors
  • Study the principles of Joule heating in electrical circuits
  • Learn about the relationship between electrical energy and thermal energy
  • Explore the concept of phonon modes in solid-state physics
  • Investigate the effects of different materials on resistive heating
Electrical engineers, physics students, and anyone interested in understanding the thermal dynamics of resistors and their applications in electronic devices.
quasar987
Griffith's saying that in a resistor, P = RI² is the rate at which heat is dissipated. Is that suposed to be intelligible to someone who has no knowledge in thermodynamics?
Can someone explain this process to me. What is HEAT? And how does the rate at which work is being done by the electrostatic force on the electrons in the resistor a measure in all point equal to that of the rate at which heat is dissipated?
Science news on Phys.org
Heat is a form of energy (measurable in Joules). The effects of electrical resistors in a circuit are analogous to friction in a mechanical system: energy is "lost." In either case, the energy is converted to thermal energy (thus, "heat is dissipated"). The effect in question is known as Joule heating: the temperature of the resistor rises as current is passed through it. That's how my toaster works anyway. I hope that helps. If my reply is too simplistic, I'm sure someone else will provide some better help soon.
Does it help to observe that [itex]\Delta W = q \Delta V[/itex], that [tex]P = dW/dt [/itex], and that the drift velocity of an electron at a certain point in a circuit is a function of only the properties of the conductor at that point ?<br /> <br /> A more intuitive approach might be to observe that electrons transfer momentum to the lattice through collisions, raising the vibrational energy of the atoms (ions) that they collide with. This large local lattice energy dissipates itself conductively through the wire (phonon modes) or through radiation.[/tex]
  • · Replies 22 ·
  • · Replies 16 ·
  • · Replies 19 ·
16K
  • · Replies 32 ·
