Upward Band Bending in n-Type Si Contacted by Metal
The discussion focuses on the phenomenon of upward band bending in n-type silicon (Si) when contacted by metal. It establishes that electrons flow from Si to the metal to align chemical potentials, resulting in a negative charge density in the metal and a corresponding depletion of positive donor levels in Si. This leads to upward band bending due to the balance between the negative charge in the metal and the donors in the depletion layer. The confusion arises regarding the chemical shift of Si 2p core-states, where the expectation of higher binding energies contradicts the observed shift toward lower binding energies, which is explained through the initial state model.
  • Understanding of semiconductor physics, particularly n-type silicon behavior.
  • Familiarity with band theory and band bending concepts.
  • Knowledge of core-level spectroscopy, specifically Si 2p core-states.
  • Basic principles of chemical potential alignment in metal-semiconductor junctions.
  • Research the "initial state model" in the context of semiconductor physics.
  • Explore the effects of charge density on core-level binding energies in semiconductors.
  • Study the implications of donor concentration on ionization energy in n-type silicon.
  • Investigate the mechanisms of electron flow in metal-semiconductor junctions.
Researchers, physicists, and materials scientists interested in semiconductor junctions, particularly those studying n-type silicon and its interactions with metals.
fk08
I am a little bit confused about the upward band bending in a n-type Si which is in contact with a metal. Suppose that electrons flow from Si to the metal to align the chemical potentials such that positive donor levels become depleted. In equilibrium one ends up with a negative charge density in the metal, that is balanced by the donors in the depletion layer of Si, which produce the upward band bending.
My problem concerns the chemical shift of Si 2p core-states, when such a junction is created. Because electrons leave the semiconductor, the repulsive Coulomb interaction between the core-state and the rest electrons should be lower (simply because there are less electrons), resulting in a shift toward higher binding energies.
So why do the Si 2p states move toward lower binding energies (higher energies), when electrons are leaving? how is this explained in the "initial state model".
The change of electron density applies to both the electron donor atoms and the Si atoms alike. Given that the concentration of donor atoms is very small, the change in ionization energy can be neglected.
  • · Replies 20 ·
