| New Reply |
Thevenin Equivalent Circuit: using open/short circuit method |
Share Thread | Thread Tools |
| Oct6-12, 10:17 PM | #1 |
http://i.imgur.com/fSRqw.png 2. Relevant equations [itex]V_{th}[/itex] = [itex]V_{oc}[/itex] 3. The attempt at a solution I got the thevenin voltage by using node voltage [itex]\frac{V2-40}{5}[/itex] - [itex]\frac{80+2V2}{5}[/itex] -8 + V2 = 0 ([itex]\frac{1}{5}[/itex] + [itex]\frac{2}{5}[/itex] + 1)V2 = 32 [itex]\frac{8}{5}[/itex]V2 = 32 V2 = 20V = Vth but I don't know how to setup the equation to find the short-circuit current. Since there's a short circuit, I believe that means no current goes through the 1 ohm resistor. I tried using a source transformation, but I got 28A as the current. Since Rth is 0.625, then the current has to be 32A. http://i.imgur.com/6Twjp.png |
| Oct7-12, 08:02 AM | #2 |
Recognitions:
With the short in place you know what the potential at terminal a is and therefore the potential across the resistor, thus handing you ix. Do KCL for the terminal 'a' node.
| Oct7-12, 10:55 AM | #3 |
I wrote the current of the 1 ohm resistor in terms of v and r, I just forgot that it was in parallel with node 2.
| New Reply |
| Thread Tools | |
Similar Threads for: Thevenin Equivalent Circuit: using open/short circuit method
| Transfer Function Mid-band Gain & Open Circuit/Short Circuit Time Constant Method | Engineering, Comp Sci, & Technology Homework | 1 | ||
| Thevenin Theorem - Open Voltage and Short Circuit Current | Engineering, Comp Sci, & Technology Homework | 5 | ||
| Open Circuit Voltage, Thevenin Equivalent | Introductory Physics Homework | 2 | ||
| Short Circuit, and open circuit question | Engineering, Comp Sci, & Technology Homework | 1 | ||
| CIRCUIT ANALYSIS: FInd the Thevenin equivalent of the circuit. 2 res - 1 IVS - 1 VCVS | Introductory Physics Homework | 2 | ||
