| Thread Closed |
Implementing hydrogen effects in constitutive modeling of metal plasticity |
Share Thread |
| Feb18-05, 04:05 PM | #1 |
I've been working on/off with problems of environmentally assisted cracking, primarily in the fracture mechanics side of things and on occation some damage mechanics work. As a continuation for this I started looking for plasticity models which introduce the effects of hydrogen directly into typical models of incremental plasticity, and so far the one I've available as a complete implementation is given by Sofronis et al, in which the hydrogen concentration is introduced to stress-strain behavior as :
[tex] \sigma_y(\epsilon_p,c)=\sigma_0[(\gamma-1)c+1](1+\frac{\epsilon_p}{\epsilon_0})^{1/n} [/tex] (local hydrogen enhances dislocation mobility -> flow stress decreases), where the yield strength [tex]\sigma_y[/tex] is dependent on the concentration [tex]c[/tex], effective plastic strain [tex]\epsilon_p[/tex], [tex]\gamma[/tex] is a softening parameter, [tex]\epsilon_0[/tex] the yield strain and [tex]\sigma_0[/tex] the yield strength for [tex] c = 0 [/tex]. The model has a number of other parameter ranging from dislocation density to specification to lattice traps etc. So the question I'm thinking about now is what else is out there, anyone got any experience on what material models are out there and might be usable considering linkage to damage / fracture mechanics ? |
| Feb18-05, 08:22 PM | #2 |
Admin
Perennial, what references do you have for Sofronis? He has done a lot of work on a lot of different materials. He has co-authored several papers with Birnbaum, and both have done a fair amount of work with Zr (hcp) alloys and effects of hydrogen.
Zr alloys are interesting since they form Zr hydride, ZrHx where x~1.6. Locally though the x~2. The hydrides dissolve at relatively low temp, and hydrogen solubility is another factor. Then to complicate matters, the dissolution temperature is different than the precipitation temperature. In general the plasticity is very localized, such that macroscopically, the material shows little strain and effectively behaves in a brittle manner. I believe this behavior is quite different for steels and Ni-alloys. ================================================ A major issue in Zr-alloys is the waterside corrosion and the hydrogen which is produced. The hydrogen which diffuses into the metal will migrate under thermal gradients and certainly will prefer to precipitate near defects, especially where tensile fields are present. This is somewhat different from the environmental hydrogen-assisted cracking in which the hydrogen forms at the crack tip (usually by a chemical or galvanic reaction) and diffuses from that point up the stress gradient. I found a TOC from a conference - Hydrogen Effects in Materials (pdf file) |
| Feb19-05, 03:52 AM | #3 |
Thanks for a great reply as always !
| Feb20-05, 03:25 PM | #4 |
.... a few years ago listed the couplings what we wanted to investigate in relation to the whole hydrogen - damage problem, went somewhere along these lines :
| Mar6-08, 10:26 AM | #5 |
If you only want to model what happens to the bulk material upon hydrogen absorption, you may be very well off changing only the bulk constitutive behavior. For instance, Sofronis, Liang, and Aravas obtained in that way the point of structural instability derived from such a bulk behavior. But you will not be able to simulate crack propagation. If you actually want to track the evolution of cracks, you need more than that. Cohesive models are very useful for this purpose, as used by Serebrinsky, Carter and Ortiz, "A quantum-mechanically informed continuum model of hydrogen embrittlement", Journal of the Mechanics and Physics of Solids 52 (2004) 2403-2430, and also Liang and Sofronis, "Toward a phenomenological description of hydrogen-induced decohesion at particle/matrix interfaces", Journal of the Mechanics and Physics of Solids 51 (2003) 1509-1531. If you decide to use cohesive models to let the crack/s evolve, then you face the issue of how to derive the appropriate constitutive behavior of the cohesive zone. And on this point there is a large literature too.
| Thread Closed |
Similar discussions for: Implementing hydrogen effects in constitutive modeling of metal plasticity
| constitutive relations | Calculus & Beyond Homework | 0 | ||
| Implementing processor | Computing & Technology | 0 | ||
| Implementing Various Calculations ith only + and - in c++ | Introductory Physics Homework | 21 | ||
| Justification for non-local and gradient constitutive models | Materials & Chemical Engineering | 2 | ||
| Gleaming hydrogen metal | Atomic, Solid State, Comp. Physics | 3 | ||
