Magnitude of electric field at a point
by Peewee
Tags: electric, field, magnitude, point
Peewee
Peewee is offline
#1
Oct10-12, 10:02 AM
P: 1
A force of 5.7 N. is exerted on a 8.8 microCoulomb charge in a downward direction. What is the magnitude of the electric field (in N./C.) at this point?
2. Relevant equations
E = (kel * abs(q)) / r^2\
E = Fel / q
3. The attempt at a solution
8.8 microcoulombs --> 8.8e-6 Coulombs
At first I tried using:
E = (8.99x9)(8.8e-6) / r^2
But I didn't understand how I was supposed to find the radius. If it were a square, rectangle, triangle etc. and given some more information I could use trigonometry to determine the radius. The equation is for a point charge, though.
I then used E = Fel / q and simply plugged and chugged to get the right answer.
My question, though, is when do I use the E = Fel / q and when do I use the E = kq/r^2 equation?
Is the point charge for when two points are being compared to each other and the E = Fel/q is for one item?
Phys.Org News Partner Science news on Phys.org
NASA's space station Robonaut finally getting legs
Free the seed: OSSI nurtures growing plants without patent barriers
Going nuts? Turkey looks to pistachios to heat new eco-city
Doc Al
Doc Al is offline
#2
Oct10-12, 11:48 AM
Mentor
Doc Al's Avatar
P: 40,883
Quote Quote by Peewee View Post
The first equation (Fel = Eq) is true in general--it relates the field to the force produced by that field on a particular charge. The second equation is for finding the field due to a point charge. (Which wasn't relevant here, as you were not given any information about the source of the field, only the force it produced on a given charge.)
Register to reply
Related Discussions
Magnitude and direction of electric field at point P Introductory Physics Homework 2
What is the magnitude of the dipole's electric field at point P? Introductory Physics Homework 1
Magnitude of electric field at a point Introductory Physics Homework 3
Magnitude of Electric Field at a Point Introductory Physics Homework 1
Magnitude of Electric field at point P Introductory Physics Homework 1
