How would one calculate Tug of war forces between two vehicles?
  • Thread starter Thread starter Mer
    Forces Vehicles
The discussion focuses on calculating the forces involved in a tug-of-war scenario between two off-road vehicles weighing 600 lbs. and 550 lbs., each equipped with 10 hp engines. Key calculations involve determining the drawbar pull, which is influenced by rolling resistance (Rr), gradient resistance (Rp), inertia resistance (Ri), and wind resistance (Rv). To estimate maximum drawbar pull, a coefficient of friction of unity is applied to the smaller vehicle, and a safety factor of 5 is recommended to account for dynamic and shock loads, ensuring robust design of the hitch made from 4130 Normalized steel tubing.
  • Understanding of basic physics principles related to force and friction
  • Familiarity with vehicle dynamics and resistance forces
  • Knowledge of material properties, specifically 4130 Normalized steel
  • Experience with engineering safety factors in design
  • Research "Drawbar Pull calculations for off-road vehicles"
  • Learn about "Coefficient of friction in vehicle traction"
  • Explore "Dynamic loading and safety factors in engineering design"
  • Study "Material properties of 4130 Normalized steel for structural applications"
Engineers, automotive designers, and off-road vehicle enthusiasts looking to understand the mechanics of vehicle towing and force calculations in practical applications.
Mer
How would one calculate "Tug of war" forces between two vehicles?
Hello! I am working on some calculations for an off-road vehicle on which we are working, and I cannot figure out which figures to use. Really, it's where to start. We have two vehicles (600 lbs. and 550 lbs.) with 10 hp engines that will be hitched together in a tug-of-war type setting. The hitches are attached to 4130 Normalized steel tubing, and I'm trying to calculate how much force is transferred (essentially how beefy we need to build it). I know this isn't a lot of information, but I have a huge brain-block. Any tips to get this started would be so appreciated!
Drawbar Pull =
Tractive Effort -
Rr=rolling resistance
Rp=gradient resistance
Ri=inertia resistance (acceleration)
Rv=wind resistance
Like many real engineering design applications, you are missing a whole lot of information required for an accurate solution. What we so in this in cases like that is to bracket the solution with a max and min solutions.
For max, assume a coefficient of friction of unity between the tires and ground. Apply that to the smaller vehicle for max draw bar pull. Then throw in a safety factor of 5, to take care of unknowns, the largest of which in this case would be dynamic and shock loads since you are not designing much energy absorption into this system.
9K
  • · Replies 27 ·
