Force on a Wire In Uniform Magnetic Field
The problem involves a long wire carrying a current in a uniform magnetic field, with the goal of calculating the y-component of the magnetic force acting on the wire. The magnetic field is described by its components in the Cartesian coordinate system.
  • Participants discuss the application of the formula for magnetic force and question the interpretation of the magnetic field components. There are attempts to clarify the relationship between the current direction and the magnetic field, as well as how to determine the angle involved.
The discussion is ongoing, with participants seeking clarification on the calculations and the underlying concepts. Some guidance has been offered regarding the use of the cross product to find the force, but there is no explicit consensus on the approach to take.
There is mention of a lack of prior instruction on handling magnetic fields given in component form, which may be contributing to the confusion among participants. Additionally, the need for more information to calculate the y-component of the force is highlighted.
bmb2009
A long wire lying along the x-axis carries a current of 2.60 A in the +x direction. There is a uniform magnetic field present, given by B=0.003i + 0.004j + 0.002k, where i, j, k are the unit vectors along the cartesian coordinate axes') in units of Tesla. Calculate the y-component of the magnetic force acting on a segment of wire of length L = 17.5 cm.
I tried using the formula F=ILBsin@
where F=force, I=Current, B=magnetic field in tesla, sin@=1 (b/c y-axis is perpendicular to x so @=90 degrees).
but that didn't work...I don't really know how to make sense of the B field equation?
Help?
hi bmb2009! :smile:
(have a theta: θ … or pick it up from the Quick Symbols box to the right of the Reply box :wink:)
no, the θ in ILBsinθ is the angle between I and B
(the force F = LI x B is perpendicular to both I and B)
that gives you the magnitude of F, then find the component in the y direction :wink:
Can you be more thorough? Like i have no idea where to start our teacher never went over anything close to something with a b field given as components... so I Don't know how to find an angle from it and even if I did I would know how to find the Y component afterwards..
I tried:
since the B field and current are parallel in the x direction the f=0
so the magnitude of the force is the force from the y and z components which i plugged into get a number but how would you calculate of Y component without any more information?
bmb2009 said:
… so the magnitude of the force is the force from the y and z components which i plugged into get a number but how would you calculate of Y component without any more information?
show us your cross product calculations for the total F :smile:
