Need help finding the thrust and exit diameter of a rocket
The discussion focuses on calculating the thrust and exit diameter of a small rocket powered by high-pressure nitrogen, with specific parameters including a throat diameter of 1.0 inch, operating pressure of 120 psi, and a temperature of 510R. The thrust equation used is F = m dot * Ve + (pe - p0) * Ae, where the user is advised to calculate the exit area using the provided equation A/A*=(1/M^2)((2/gamma+1)(1+(gamma-1/2)M^2))^(gamma+1/gamma-1). The user also seeks to compare thrust and exit diameters at exit Mach numbers of 5.0 and 7.0, indicating a need for precise calculations based on the given conditions.
  • Understanding of rocket propulsion principles
  • Familiarity with thermodynamics, specifically the ideal gas laws
  • Knowledge of fluid dynamics, particularly compressible flow
  • Proficiency in using thrust equations and area calculations in rocket design
  • Research the calculation of exit area in rocket nozzles using compressible flow equations
  • Study the effects of varying Mach numbers on thrust and exit diameter
  • Explore the implications of operating pressures and temperatures on rocket performance
  • Learn about the specific impulse and efficiency of high-pressure nitrogen propulsion systems
Aerospace engineers, rocket propulsion specialists, and students studying fluid dynamics and thermodynamics in rocket design will benefit from this discussion.
strine07
A small rocket powered by high-pressure nitrogen (R = 1776 ft-lb/slug/R, gamma=1.4) is used as an attitude control device. In space, the thrust of a rocket is given by T =mVe
in lbf. Find the thrust and exit diameter of this rocket with a throat diameter of 1.0 inch if it
operates at PT = 120 psi and TT = 510R with M = 3.0 at the exit. Then compare the
thrust and exit diameters when the exit Mach number is 5.0 and 7.0.
*I know I need to use the equation A/A*=(1/M^2)((2/gamma+1)(1+(gamma-1/2)M^2))^(gamma+1/gamma-1) but I'm having trouble finding the appropriate values.
ps sorry if this post is in the wrong area, I'm pretty new to this site!
You've got everything you need, except for this part. The thrust equation is:
Calculate the exit area from the equation you listed. You've been given everything else. Or just look up the old tables.
  • · Replies 23 ·
