Measuring Current with Multimeter, Power Supply & Resistors
  • Context: High School
  • Thread starter Thread starter Haftred
    Current Measuring
The discussion revolves around measuring current in a circuit using a multimeter, a power supply, and resistors. Participants seek guidance on how to properly connect the multimeter in series to measure current, especially in the context of a parallel circuit setup. The conversation includes concerns about avoiding damage to the multimeter and understanding the correct use of multimeter terminals.
  • Homework-related
  • Some participants express uncertainty about how to connect the multimeter in series, particularly in a parallel circuit configuration.
  • There are mentions of the need to disconnect wires or resistors to insert the multimeter correctly, but specific instructions vary.
  • Concerns are raised about the risk of damaging the multimeter if the current exceeds the scale setting, with suggestions to check the multimeter's specifications.
  • Some participants propose using a known resistor in series to measure voltage as an alternative method to avoid damaging the multimeter directly.
  • Questions arise regarding the correct use of the multimeter's terminals, specifically the significance of the black and red leads.
Participants generally agree on the need to measure current in series, but there is no consensus on the specific steps to take or the best practices to avoid damaging the multimeter. Multiple competing views on the method of connection and safety precautions remain.
Some participants mention the importance of checking the multimeter's manual for specific instructions, indicating that there may be variations in multimeter designs and features that affect how current should be measured.
Haftred
I wasn't sure where to post this, so feel free to move this thread if necessary. I want to measure the current of a circuit using a multimeter, a power supply, and 3 resistors. How do I insert the "rods" on the multimeter to measure the current in the circuit? I know I have to measure it in series, but where do I disconnect the wires/resistors in the circuit, and how do I insert the "rods" in the multimeter to measure the current. Also, how do I make sure I don't blow a fuse? Thanks!
The multimeter will in general have a current setting - for a direct measurement of current, you set the multimeter on a current scale, put the meter in series with the circuit, and measure the current.
There is a potential risk to the multimeter if the current is very high (well beyond the scale setting on the multimeter) and you measure the current in this manner. This can happen unintentionally if the circuit you are measuring is shorted, for instance. There's no risk if you set the multimeter to the proper current setting. Some multimeters have a special set of terminals for high current readings, you have to look at the multimeter to see if yours has such arrangement.
You can also put a resistor of known value in series with the circuit (but a resistor that's also small enough not to seriously disturb the current flowing through the circuit) and then measure the voltage across the resistor with the multimeter. This is a less direct measurement, but it has the advantage that if something goes wrong, you only fry the resistor you put in series, not the multimeter. You still have some chance of bending the needle if it's an analog meter and the voltage range setting is wrong.
this may be a stupid question, but how do I connect the multimeter in series? I want to measure the different currents in a parallel setup, but I don't know what to disconnect and where to disconnect it; also there are two different colours on my multimeter (black and red) and I don't know what to put where. Thanks.
If the original circuit is
-----load------------------
then either
----load----multimeter-----
or
---multimeter----load------
is a series connection
So you have to break or disconnect a wire where you want to measure the current, and insert the multimeter in series, with the correct range setting. The current has to flow into the positive terminal of the multimeter and out of the negative one if it's an analog meter, because an analog meter can't measure a negative current properly. If the needle tries to move the wrong way, then you put it in backwards. If it's a digital meter, it'll probably read read a negative current.
Be careful, sometimes meters have different terminals on the front for measuring currents - when in doubt read the directions or manual for your meter.
  • · Replies 52 ·
  • · Replies 57 ·
15K
  • · Replies 105 ·
14K
  • · Replies 16 ·
