Electrical Resistivity Equation
The discussion revolves around the electrical resistivity equation and its application in calculating the current through a copper wire given specific parameters such as voltage, length, and resistivity. Participants are exploring the relationship between resistivity, resistance, and current in the context of a practical problem.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants discuss the correct application of the resistivity equation and its rearrangement to find resistance. There is a focus on ensuring the correct interpretation of given parameters, such as distinguishing between resistivity and resistance.
Some participants have provided guidance on the correct approach to calculating resistance before applying Ohm's law to find current. There is an acknowledgment of the need to check units and ensure proper understanding of the problem setup.
There is a noted confusion regarding the use of the wire's radius versus its cross-sectional area, which has implications for the calculations being discussed. Participants reflect on the importance of carefully reading problem statements to avoid errors.
Matt.D
Is the correct equation that relates to the electrical resistivity of a conducting material to its resistance:
p = RS/l
p = is the electrical resistivity
R = is the resistance of the material
S = is the cross-sectional area
l = is the length of the specimen
if I'm using the right formula, would my answer to this question be correct?
A potential difference of 1.5V exists across the ends of a copper wire of length 2.0m and uniform radius 0.40mm. Calculate the current in the wire.
I've been given the resistivity of copper as 1.7 x 10^-4 ohms.meter
[Answer]
p = RS/l
= (1.7 x 10^-4) x 0.40mm / 2.0m
= 0.0007 x 0.0004 / 2.0
= 0.00000014
corecto?
p = RS/l
That's correct.
Only if you use it correctly!
p = RS/l
= 0.00000014
Not correct. (If you checked the units of your calculation, you'd see that things don't match.)
First, you need to calculate the resistance (R) of that piece of copper wire, not the resistivity ([itex]\rho[/itex], which is a fixed property of copper). You are given the resistivity, not the resistance. Rearrange that formula as so:
[tex]R = \rho L / S[/tex]
Once you find the resistance, then you can use Ohm's law to find the current.
Thanks Doc!
Using the rearranged formula I've calculated:
R = pl/S
R = 0.0007 x 2.0 / 0.0004
R = 0.0014 / 0.0004
R = 3.5 Ohms
Using Ohms Law
I = V/R
I = 1.5V (as stated in the question) / 3.5 ohms
I = 0.42857..
I = 0.43
You are given the radius of the wire, not its cross-sectional area.
Thanks Gokul! I've really got to start reading questions more thoroughly.. I'm losing marks like this all of the time :rolleyes:
  • · Replies 23 ·
