Combining air pressures - Time to reach equilibrium
The discussion revolves around deriving a relationship between the radius of a hole connecting two compartments with different pressures and volumes, and the time required for the pressures to reach equilibrium. Participants explore theoretical aspects, mathematical modeling, and assumptions related to gas behavior under changing conditions.
  • One participant seeks to establish a relationship involving the radius of a hole, pressures, and time to equilibrium, while expressing uncertainty about the starting point and necessary detail.
  • Another participant suggests relating speed to pressure difference and the amount of matter in each compartment.
  • A participant mentions using Bernoulli's equation to connect pressure difference to flow velocity and has derived an expression for mass flow rate.
  • Concerns are raised about integrating the mass flow expression over time and the impact of varying pressure differences on the flow rate.
  • Participants discuss the need to assume constant temperature and question the relevance of friction factors in the flow analysis.
  • One participant expresses uncertainty about the correctness of their derived equations and the treatment of changing pressure differences in their mass flow expression.
  • Questions arise regarding the necessity of using different density values for each compartment in the velocity equation.
Participants do not reach a consensus on the correct approach to modeling the problem, as multiple viewpoints and uncertainties regarding the equations and assumptions persist throughout the discussion.
Participants highlight limitations regarding the treatment of changing pressure differences, the integration of mass flow expressions, and the assumptions made about temperature and density. These factors contribute to the complexity of the problem without resolving them.
oujapuja
I need to produce a relationship between the radius of a hole between compartment A (Pressure P1, Volume V1) and compartment B (P2, V2) and the time it takes for these pressures to reach an equilibrium point. I am assuming the gases begin at the same temperature at this point. I'm struggling for a starting point and can't see where the time relationship comes from. I am also wondering how much detail I need to go into to get an accurate relationship and would be grateful for any hints or tips on how to tackle this, Thanks.
welcome to pf!
hi oujapuja! welcome to pf! :smile:
find how speed relates to pressure difference, and how speed relates to the amount of matter in each compartment :wink:
Thanks for your reply tim. I haven't had to do calculations like this for a long time so I'm very rusty, so thanks for the advice.
I've used Bernoulli's equation to link the pressure difference to flow velocity and have an expression for mass flow rate. I've also worked out an equation for the additional mass added to the lower pressure compartment using the ideal gas law (I think!).
My thinking is if I integrate my mass flow expression for the change in mass and change in time, using my limits as the additional mass I have calculated, this will yield the time taken? If I can deal with the following problem (hopelessly optimistic of me).
The other issue I am struggling with is the varying pressure difference in my mass flow expression and am unsure of how to deal with it. Tried a few replacements using the ideal gas law, but couldn't seem to get anywhere.
I'm also wondering how much effect the hole will have on the flow and I wonder whether I need to use a friction factor, somewhere (again, very rusty, sorry!).
Any tips again would be great. I'm quite keen on solving this, so thanks for not just solving it for me!
hi houjapuja! :smile:
it's a little difficult to advise when you haven't shown your equations
for the hole, just use Bernoulli's equation, and forget friction etc
i think you'll have to make an assumption about temperature … i'd assume the temperature stays the same :wink:
From Bernoulli's equation, I have the following for velocity U:
U=[itex]\sqrt{\frac{2*(P1-P2)}{ρ}}[/itex]
My mass flow equation is then:
mass flow rate = A*[itex]\sqrt{2*ρ*(P1-P2)}[/itex] (A - Cross Sectional Area of hole)
Using: Mass in compartment B at equilibrium = original mass + additional mass (Ma)
Using the ideal gas law to find masses, I arrived at the following:
Ma = [itex]\frac{V2}{V1+V2}[/itex]*[itex]\frac{P1*V1}{R*T1}[/itex] - [itex]\frac{V1}{V1+V2}[/itex]*[itex]\frac{P2*V2}{R*T2}[/itex]
Again, I'm unsure if this is correct.
As I mentioned, I was thinking it would be correct to integrate my mass flow expression with mass limits (0, Ma) and time Limits (0, t), aiming to find t.
If all this is correct then the problem for me lies in the flow velocity as this will be changing with time. Am I right in trying to substitute the pressure difference in terms of mass?
hi oujapuja! :smile:
looks ok (but what is ρ in your first equation?)
your Vs and Ts are constants,
so you have equations for Ma and dMa/dt which you should be able to solve
Sorry for the late reply!
I didn't even think of the density - should there be two density values (one for each side) in my velocity equation?
I know that the equation for Ma is a constant, calculated with inital pressure values. But what I am still unsure on is the value of (P1-P2) in my mass flow expression - won't this change with changing mass in each side hence affecting the mass flow expression? How can I incorporate this into my equation? I've tried replacing them with various expressions from the ideal gas law etc. but the equation turns into a horrible mess.
  • · Replies 45 ·
  • · Replies 16 ·
