Register to reply
Lifting a Box - Work and Power
by cowmoo32
Tags: lifting, power, work
Share this thread:
cowmoo32
#1
Oct17-12, 07:10 PM
P: 120
A 7-kg box is being lifted by means of a light rope that is threaded through a single, light, frictionless pulley that is attached to the ceiling. If the box is lifted, at constant acceleration, from rest on the floor to a height of 1.5 m above the floor in 0.42 s, what average power is delivered by the person pulling on the rope?
2. Relevant equations
(1) d = V0t + 0.5at2
(2) F=ma
(3) W = Fd
(4) P = W/Δt
3. The attempt at a solution
(1) a = 17m/sec2
(2)
F = 7*17
F = 119
(3)
W = 119*1.5
W = 178.5
(4)
P = 178.5/0.42
P = 425
Here's the thing, that answer agrees with the equation in the solution manual, but not on my homework. I'm reworking an old problem and I got it correct the first time around and can't figure out how I arrived at the answer, which is 0.67kW.
Phys.Org News Partner Science news on Phys.org
Experts defend operational earthquake forecasting, counter critiques
EU urged to convert TV frequencies to mobile broadband
Sierra Nevada freshwater runoff could drop 26 percent by 2100
cepheid
#2
Oct17-12, 08:46 PM
Emeritus
Sci Advisor
PF Gold
cepheid's Avatar
P: 5,196
Quote Quote by cowmoo32 View Post
(2) F=ma
(3) W = Fd
(4) P = W/Δt
(1) a = 17m/sec2
(2)
F = 7*17
F = 119
(3)
W = 119*1.5
W = 178.5
(4)
P = 178.5/0.42
P = 425
Method 1: Using Forces
119 N is the NET force that is applied to the object. Therefore the work you calculated is the NET work done on the object. However, in order to get this net force upward, the person has to apply this force PLUS the weight of the object. So he does more work than what you computed, because he or she also has to do work against gravity. The work done against gravity goes into increasing the object's potential energy, whereas the net work done by the net force goes into increasing its kinetic energy. Anyways:
Fnet = Fapplied + weight = Fapplied - mg
Fapplied = Fnet + mg = 119 N + (7 kg * 9.81 N/kg)
= 187.67 N
Wapplied = (187.67 N * 1.5 m) = 281.5 J
P = W/Δt = 281.5 N/0.42 s = 670.25 W
Method 2: Using Energies
This method is not really different mathematically, it's only different conceptually. The power is the rate at which energy is delivered by the person, so to find the average power, just take the total energy expended by the person, and divide it by the time interval. The total energy is the amount by which the energy of the object increases, which is the sum of its changes in potential and kinetic energies:
E = (1/2)mvf2 + mgh
vf2 = 2ad = 2*(17 m/s2)*(1.5 m) = 51 m2/s2
E = 0.5*(7 kg)*(51 m2/s2) + (7 kg)*(9.81 N/kg)*(1.5 m) = 281.5 J.
P = E/Δt = 670.25 W
cowmoo32
#3
Oct18-12, 11:15 AM
P: 120
Thanks!
Register to reply
Related Discussions
Work lifting cable and work pumping water Introductory Physics Homework 1
Work and power when lifting weights Classical Physics 2
Lifting power of Compressed Air General Physics 1
Work done in lifting a box Classical Physics 7
Is work done in lifting an object with a spring more than lifting it with a rod? Classical Physics 6
