Could the Formation of Great Voids be Explained by Ordinary Laws of Motion?
  • Context: Graduate
  • Thread starter Thread starter codex34
The discussion revolves around the nature and formation of great voids in the universe, exploring whether ordinary laws of motion can explain their existence and characteristics. Participants examine concepts related to vacuum pressure, the behavior of matter in low-density regions, and the implications for dark matter.
  • One participant questions the conditions under which a vacuum can exist without matter being destroyed or transformed, proposing a relationship between vacuum pressure and the nature of voids.
  • Another participant defines a void as an area of low density, asserting that matter is not destroyed within these regions and challenges the notion of space as a physical entity that can move.
  • A different viewpoint suggests that the expansion of space and its ripples may imply that space could be considered a physical object, raising questions about the terminology used to describe it.
  • One participant discusses computer simulations that illustrate how particles condense under Newtonian laws to form structures, arguing that these patterns emerge naturally without needing additional theories.
  • Another participant emphasizes that voids are not entirely devoid of matter, noting that they contain less matter than average due to gravitational influences from surrounding regions.
Participants express differing views on the nature of voids, the definition of space, and the applicability of Newtonian physics to cosmic structures. No consensus is reached on these topics, and multiple competing perspectives remain present.
Some statements rely on assumptions about the definitions of vacuum and void, as well as the interpretation of simulations. The discussion does not resolve the complexities surrounding the behavior of matter and space in these contexts.
codex34
I know the title sounds stupid, but I have a serious question.
If you look at the simulations for the massive structures in the universe, there are great voids and large areas of matter in between them.
The matter parts of the universe contain gravitation objects with large masses, and from the simulations it looks like these areas have sucked all of the matter out of the voids, which is why they are voids, technically low density vacuums.
So the question is two fold,
1) at what pressure/temperature can a vacuum exist at before the matter in it is destroyed/changed to something else?
2) If an area within the 'void' moves, the vacuum pressure where it moves away from increases, if there is a maximum vacuum pressure (at which vacuum become void) then the surrounding space would attempt to fill the void, which it couldn't do because this would create more void. So could we consider these great 'voids' to be inelastic in nature?
Could the 'voids' be considered as a single (soft/hard) body, which increases in elasticity nearer the edges?
What does that do to the dark matter problem if we consider the 'voids' to be immense solid bodies that slowly rotate?
Astronomy news on Phys.org
A void is simply a large area where the density of matter is much less than the average. It is still a vacuum. Matter is never destroyed or changed into something else inside the voids. Space is not a physical object and cannot move to fill anything. Only matter can do this.
and yet it expands in time...and its rippled in some areas. i think..eigther we use the wrong words to define space or we should consider it a physical object.
The metric is a mathematical construct that describes spacetime in General Relativity. The metric is what is expanding and is what gravity waves are "in". Whether this applies literally to "actual" spacetime or not is unknown. All we know is that it accurately describes the observed behavior of objects within spacetime, including the fact that they are receding away from each other and that they can lose energy in the form of gravitational waves. (That we haven't been able to detect yet)
The argument of whether spacetime should be regarded as "something" or just a framework is one that is mostly pointless in my opinion. How would we even know?
codex34 said:
If you look at the simulations for the massive structures in the universe, there are great voids and large areas of matter in between them...
It helps to watch the whole movie and not merely look at a few stills.
There are computer simulations that show an almost uniform cloud of particles condensing (under ordinary Newton laws of motion) to form wispy cobwebby structures with some lower-density pockets. They fall together naturally, by their own gravity, to form the observed structures.
I think the only special or modern thing about those simulations is that the effect of uniform xyz expansion is put in by SLOWING the motion down very gradually. I think that slowing effect is put in. Otherwise it is just a computer movie of a cloud of particles attracting each other by standard Newton gravity pull and moving in a standard rectilinear xyz frame.
So the patterns that form do not need any explanation. The computer is explaining how the cobwebs form---by applying the simplest classical laws of motion to a cloud of particles in the simplest possible framework.
What you see happening, when you watch the movie, is happening completely naturally according to the most basic understanding. So we don't need to make up a "jello theory" or any other additional explanations.
Of course we don't ultimately know that the laws of conventional physics are RIGHT, all we can say in this case is that the conventional model reproduces the appearance of reality with surprising accuracy and in a remarkably simple way. The key thing is having a computer that is big and fast enough to handle 100s of thousands of particles each one moving bit by bit in response to the pull of the others. That's what makes the cobwebs with their comparatively empty pockets.
BTW in reality the "voids" we see are not completely devoid of galaxies, they have matter in them like every place else, just a lot less than average. Or so I'm told anyway--I've not personally studied them. The idea is that the pull from surrounding higher-density regions has drawn out most of their stuff making them comparatively (but not perfectly) empty. Stuff "falls" from lower density into higher density regions, whether it be gasclouds, dust, galaxies, or dark matter.
  • · Replies 31 ·
