Solving a system of linear equations
The discussion revolves around determining two third degree polynomials, p and q, based on specific conditions related to their values and derivatives at certain points. The problem involves solving a system of linear equations derived from these conditions.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the validity of using substitution to solve the system of equations. Some express concerns about the correctness of the derived equations and whether certain assumptions about coefficients can be made. Others suggest that the original poster may have made transcription errors in their equations.
The conversation is ongoing, with various participants providing feedback on the original poster's approach. Some guidance has been offered regarding the use of substitution and the potential need for matrix methods, but no consensus has been reached on the correctness of the original equations or assumptions.
There is mention of the original poster's confusion regarding the linear algebra concepts involved, and the discussion includes references to the number of equations versus unknowns, which may impact the solution space.
Mathman23
Hi
I have obtain two third degree polynomials p and q which are determint by the following conditions:
p(-1) = 1 , p'(-1) = 0
q(1) = 3 , q'(1) = 0
p(0) = q(0) , p'(0) = q'(0)
where p = a_1 * x^3 + b_1 *x^2 + c_1 *x + d_1
q = a_2 * x^3 + b_2 *x^2 + c_2 *x + d_2
I then end up with the the following linear equations by inserting the conditions into the equations above:
-a_1 + b_1 - c_1 + d_1 = 1
3* a_1 - 2 * b-1 + c_1 = 0
c_1 = d_1
3* a_2 + b_2 + c_2 + d_2 = 3
3 * a_2 + b_2 + c_2
d_1 = d_2
By the use of substitution I obtain the result, that
a_1 = 1/5 , b_1 = 34/5 , c_1 = d_1 = -15/5
My question is it correct to use substitution? If yes can I use approach to obtain a_2, b_2, c_2 and d_2 ?
Sincerley
Fred
I think your approach is, at least in principle, sound. However, it doesn't seem like you're getting the right equations.
You have:
[tex]p_1(x)=a_1x^3+b_1x^2+c_1x+d_1[/tex]
and
[tex]p_2(x)=a_2x^3+b_2x^2+c_2x+d_2[/tex]
Then you can convert your other conditions:
[tex]p_1(0)=p_2(0) \Rightarrow d_1=d_2[/tex]
like you have, but I don't see
[tex]p_1'(0)=p_2'(0) \Rightarrow c_1=c_2[/tex]
Which may be due to a transcription error. (I'm not going to speculate further on that.)
Moving on from there, you can certainly solve the system of equations using substitution, or some other method.
Hi and thanks for Your answer,
My problem concerns cubic splines. I'm suppose to determine two third degree polynomials p and q from the conditions given in my earlier post.
My linear Algebra book doesn't explain this process very well, so I would very much appricate if someone could direct me to a website which explains this process and which hopefully could contain a couple of examples.
Thanks in advance,
Sincerely
Fred
You have:
and
When you've got a polynomial like
[tex]p(x)=ax^3+bx^2+cx+d[/tex]
and something like
[tex]p(1)=5[/tex]
you can just substitute the value in for x. I.e.
[tex]p(1) \equiv a1^3+b1^2+c1+d[/tex]
You shouldn't have to deal with solving any kind of cubic to do this problem if you substitute in the x in all of the expressions.
You have:
and
The original post (maybe it had been edited before I saw it)
said that p1[/sup]'(0)= 0, p2'(0)= 0
That would certainly give c1= 0, c2= 0!
You mean I need to put it into a matrix in order to solve it?
/Fred
and something like
[tex]p(1)=5[/tex]
/Fred
Not really, no. (Although that is an option.) There are many different ways to solve systems of linear equations.
If you have
[tex]p(1)=5[/tex]
and
then you have
[tex]5=p(1)=a1^3+b1^2+c1+d=a+b+c+d[/tex]
so
[tex]5=a+b+c+d[/tex]
What I mean is that in order to solve your system, you don't need any cubics or quadratics since you can just substitute into get a linear system of equations in the cooeficients.
Hi
If I assume that [itex]c_{1} = c_{2} = d_{1} = d_{2}=0[/itex]
Then the system of equations is reduced to:
[itex]1 = -a_{1} + b_{1}[/itex]
[itex]0 = 3a_{1} - 2b_{1}[/itex]
[itex]3 = a_{2} + b_{2}[/itex]
[itex]0 = 3a_{2} + 2b_{2}[/itex]
I then solve the above as two systems of equations and then obtain the following values [itex]a_{1}= 2 , b_{1} = 3 , b_{2} = -6 , a_{2} = 9[/itex]
This in turn generates two 3 degree polynomials: [itex]p(x) = 2 x^{3} + 3x^2[/itex] and [itex]q(x) = -6 x^{3} + 9 x^{2}[/itex]
Finally I preform a test by inserting the values: p(-1) = 1, q(1) = 3, p(0) = q(0), p'(-1) = 0, q'(1) = 0, p'(0) = q'(0) into their respective polynomials.
I then discover that the polynomials give the desired result mentioned above.
My question is: Doesn't that mean that my approach is correct?
Sincerley
Fred
You have found a solution to the system of equations. Since you have 6 equations, and 8 unknowns, there will be an infinite number of solutions, or no solutions at all.
p(-1) = 1,
p'(-1) = 0,
q(1) = 3,
q'(1) = 0,
p(0) = q(0),
p'(0) = q'(0)
[tex]p(x)=a_1x^3+b_1x^2+c_1x+d_1[/tex]
[tex]q(x)=a_2x^3+b_2x^2+c_2x+d_2[/tex]
So, chose any [tex]c,d[/tex] that you like. Then:
[tex]c_1=c_2=c[/tex]
[tex]d_1=d_2=d[/tex]
[tex]a_1=c-2d+2[/tex]
[tex]b_1=2c-3d+3[/tex]
[tex]a_2=2c+2d-6[/tex]
[tex]b_2=9-3c-3d[/tex]
Is going to solve your system of equations.
