Calculating Average Force from Water Flow Rate and Height
  • Thread starter Thread starter mooshasta
    Physics Test
The problem involves calculating the average force exerted by water falling from a drainpipe, given the flow rate and height of the fall. The subject area pertains to mechanics, specifically the concepts of momentum and force in fluid dynamics.
  • The original poster attempts to understand how to relate the flow rate of water to its velocity and the resulting force upon impact. Some participants discuss the momentum change of the fluid and its relation to gravitational potential energy, while others clarify the calculations involved in determining average force.
Participants have engaged in a detailed exploration of the problem, with some providing mathematical formulations and clarifications. There is an acknowledgment of the calculations leading to a specific numerical answer, but no consensus on the methodology has been reached.
The original poster expresses uncertainty due to the lack of information regarding the diameter of the pipe, which they believe is necessary for determining the velocity of the water. Additionally, assumptions about the behavior of the water during its fall are being discussed.
mooshasta
Hey.. I was looking over a physics team test, and I can't figure out how to solve this problem. I've asked my teachers and they can't help me either.
Water runs out of a horizontal drainpipe at a rate of 120 kg per minute. It falls 3.2 m to the ground. Assuming the water doesn't splash up, what average force does it exert on the ground?
I'm not sure where to start with this- I believe that if the diameter of the pipe was given, you could find the velocity of the water, but without it I'm not sure where to begin. Just a little help would be greatly appriciated. :smile:
The change in the momentum of a particle of fluid in the vertical direction equals the negative of (its mass)* sqrt(2* acceleration due to gravity* 3.2m). This momentum is transferred to the ground ( assuming, as you said, the water doesn't splash around). Since the particles weighing 120kg fall on the ground per minute, the average force is
- (120)*sqrt( 2*acc. due to gravity* 3.2) Newton per min.
A fluid particle may have a velocity in the horizontal direction, but it remains unchanged throughout the fall & the fluid continues to flow along the ground. I assumed, based on the few drainpipes I've seen in my life :smile: ,that initially the vertical component of the velocity was negligible.
I am, with great respect,
Einstone.
To clarify Einstone's solution, we have for the momentum of fluid mass "m":
p = m*v
Δp = m*Δv
{Average Force During Time ΔT} = Δp/ΔT = m*Δv/ΔT
The kinetic energy change of fluid mass "m" is related to the work performed by gravity over distance "d" on "m" by:
Δ{(1/2)*m*(v^2)} = (1/2)*m*{(vf)^2 - (vi)^2} = F*d
Or in this case, since vi=(0):
(1/2)*m*(vf)^2 = m*g*d
vf= sqrt{2*g*d}
Δv = sqrt{2*g*d} - 0 = sqrt{2*g*d}
{Average Force On Ground During Time ΔT} = -Δp/ΔT =
= -m*Δv/ΔT = -m*sqrt{2*g*d}/ΔT =
= -(120 kg)*sqrt{2*(9.8 m/sec^2)*(3.2 m)}/(60 sec)
= (-15.84 N)
Thank you so much, 16 N was the answer given. :)
  • · Replies 16 ·
