Heisenberg's Uncertainty Principle: Philosophical Implications
The discussion revolves around the philosophical implications of Heisenberg's uncertainty principle, exploring its interpretations and relevance in both quantum mechanics and broader philosophical contexts. Participants seek to understand the nuances of uncertainty as it relates to measurement and reality.
  • One participant notes that discussions about the observer's influence on measurement often misrepresent the uncertainty principle, which is fundamentally about the inherent limitations in predicting certain pairs of observables, such as position and momentum.
  • Another participant emphasizes that the uncertainty principle implies a fundamental limit to knowledge about certain properties of particles, rather than being merely a result of measurement disturbance.
  • There is mention of recent experiments that challenge traditional quantum intuitions, such as non-interacting measurements that can theoretically determine outcomes without disturbing the system.
  • A participant argues that the philosophical implications of uncertainty are negligible at macroscopic scales, where the effects average out, suggesting that the principle primarily applies to individual particles rather than larger systems.
  • Some participants express a desire for deeper insights into the philosophical implications, indicating a gap in available resources on the topic.
Participants express differing views on the relevance and implications of the uncertainty principle in philosophy. While some argue for its significance at the quantum level, others contend that its effects are inconsequential when considering larger systems. The discussion remains unresolved with multiple competing perspectives.
Participants highlight the complexity of understanding the uncertainty principle, noting that interpretations can vary significantly based on the scale of the system being considered. There is also an acknowledgment of the limitations in available resources for exploring these philosophical implications in depth.
106267
I've been reading extensively around the internet and haven't been able to find a website which describes the philosophical implications of Heisenberg's uncertainty principle. Would appreciate if someone would explain these implications or provide a link in which describes them. thx
The problem is at the philosophical level you will find discussions about the observer observing a system in a sense unpredictably jolting it and leading to an imprecision in the measurement. This is highly vivid, pictorial and played a role in the early development of QM.
The thing though is it is wrong. It really is a deduction from the fundamental postulates of QM for certain observable's such as position and momentum. You see in QM you generally can not predict the outcome of an observation but only probabilities. What the uncertainty principle is about is the spread of those outcomes. If you know the position of a particle with high accuracy (ie the spread of possible outcomes is small) then the spread of the possible outcomes of a measurement of momentum is large, and conversely. The philosophical issue is the principles of QM imply you can not know certain observable's with a high degree of precision at the same time - reality is unknowable exactly.
In fact even those conversant with the machinery of QM can fail to understand this being imbued with the early discussions based on vivid visualizations. Check out:
http://io9.com/5942921/scientists-now-uncertain-about-heisenbergs-uncertainty-principle
Captainmuon gave the correct analysis:
The uncertainty principle doesn't say that you always disturb a system when you measure it. That is a common misconception. It says that you cannot know, for example, momentum and position completely precise at the same time. Not because you have fat fingers, but because a particle just doesn't have those properties at the same time. *)
There have been a couple of nice experiments in the last years that go against "quantum intuition" and perform non-interacting measurements. Famous is the quantum bomb detector, that can tell (theoretically) if a single-photon triggered bomb will explode or not, without actually setting it off. Crazy stuff.
(*: Think of a perfect, infinite wave shape (°º¤ø,¸¸,ø¤º°`°º¤ø,¸,ø¤°º¤ø,¸¸,ø¤º°`°º¤ø,¸¸,ø¤º°`°º¤ø,¸,ø¤°º¤ø,¸¸,ø¤º°`°º¤ø,¸ ). This has a perfect, known wavelength, but no real position (because it goes infinitely in both directions). Contrast this with a localized wave, like on an ocean (,¸.•´¯`•.¸¸). You can now say where it is, and measure the wavelength, but not with so much accuracy as it doesn't repeat itself. That's basically the core of the uncertainty principle. If you want to know the details, all you have to understand is the Fourier transform. It really all makes sense and is not magic at all once you know the math.)
Thanks
Bill
I understand what your saying, however, i'll looking for an in deoth understanding of the Philosophical implications of uncertainty as i can't find it on most websties ?
The philosophical implications are at a scale that is inconsequential to philosophy (itself a concern that exists only on scale of the vary large human brain). By the time several billion particles are joined to make a philosophical comment about, the uncertainty has been averaged out to a pretty definite trend. The mutually exclusivity of the properties you measure only applies to the single particle that you are measuring at the moment you measure it. For a baseball it is fine to know the velocity of a billion of those particles while knowing the position of a separate billion or even know the position of the baseball now and a fraction of a second later know its velocity.
Here is one:
http://plato.stanford.edu/entries/qt-uncertainty/
But please read it bearing in mind what I said.
Thanks
Bill
Sorry, we no longer have a philosophy forum.
  • · Replies 71 ·
9K
  • · Replies 16 ·
  • · Replies 175 ·
14K
  • · Replies 52 ·
