Just a basic Series/Parallel circuit
  • Thread starter Thread starter qwexor
    Circuit
The discussion revolves around a circuit analysis problem involving resistors with values of 4, 9, 4, and 6 ohms. The original poster expresses confusion regarding the configuration of these resistors in terms of series and parallel arrangements.
  • Conceptual clarification, Problem interpretation
  • Participants suggest identifying which resistors are in parallel and which are in series, with one participant recommending replacing the top 4 and 9 ohm resistors with an equivalent resistor. There is also encouragement to redraw the circuit diagram to aid understanding.
The discussion is active, with participants providing guidance on how to approach the problem. Suggestions have been made to redraw the circuit for clarity, and there is acknowledgment of the potential for misleading diagrams.
The original poster has indicated a lack of clarity due to the diagram provided, which may not effectively convey the circuit's configuration. There is an implication that homework constraints may affect how the problem is approached.
qwexor
Ok I'm just having some concept problems with some of my homework. I have the following circuit.
http://members.shaw.ca/qwex/circuit.jpg
I am not sure what to do iwth the 4, 9, 4 and 6 ohm resistors. Which ones are in parallel or in series. Any help would be great.
Sorry for the bad diagram
clearly the top 4 and 9 ohm resistors in your diagram are in parallel, replace them with an equivalent resistor then redraw your diagram, you should be able to reduced it further.
Thank you, that's all i need to know
Try redrawing the diagram! It may help you figure out the series/parrallel confusion you are having. The circuit can be drawn in numerous ways, the question is which one helps you see it in a way so that you can esily set up your equations and do the math.
Teachers sometimes like to confuse you with diagrams that seem misleading.
