Nutrino Mass and Oscillation problem
  • Context: Graduate
  • Thread starter Thread starter FeynmanIsCool
    Mass Oscillation
The discussion revolves around the properties of neutrinos, specifically their mass, speed, and oscillation behavior. Participants explore the implications of neutrinos potentially traveling at the speed of light and the consequences for their oscillation between different types (flavors) of neutrinos. The conversation touches on experimental observations and theoretical considerations within the context of physics.
  • Some participants assert that neutrinos are said to travel at the speed of light, while others clarify that they travel "close to the speed of light," indicating a distinction that may not be observable with current experiments.
  • A participant references historical measurements of neutrino speed, suggesting that results indicate speeds very close to, but not exactly at, the speed of light, with significant uncertainty in the measurements.
  • There is a discussion about neutrino oscillations requiring time, raising questions about how neutrinos can oscillate if they are traveling at the speed of light, where time is said to stop according to relativity.
  • Some participants express skepticism about claims of neutrinos traveling faster than light, suggesting that such claims are based on miscalculations.
  • One participant notes that neutrino masses are on the order of milli-electron volts, which implies that their speed is very close to, but not equal to, the speed of light, and that current experiments lack the sensitivity to detect small deviations from this speed.
  • Another participant mentions a general consensus that neutrinos have mass and travel near the speed of light, but acknowledges that oscillation implies they must travel slower than light, while also referencing theoretical models that suggest possible Lorentz-violating behaviors.
  • Questions arise about whether gamma-ray flashes emit neutrinos, with references to research that suggests high-energy neutrinos could be produced at different times than gamma-ray emissions.
Participants express a mix of views regarding the speed and mass of neutrinos, with some asserting a consensus on their mass and speed being near light, while others highlight ongoing uncertainties and the lack of definitive measurements. The discussion remains unresolved on several points, particularly regarding the implications of neutrino oscillations and the exact nature of their speed.
Limitations include the lack of sensitivity in current experiments to measure small deviations from the speed of light for neutrinos, as well as unresolved questions about the implications of neutrino oscillations in relation to their speed and mass.
FeynmanIsCool
I have a question:
Excuse me if this has been answered on here. Neutrino's are said to travel at the speed of light. As we know anything with mass cannot travel at c. We have also observed neutrino "influxes" at the same time we observe a super nova, which means that neutrino's and photons are traveling at the same speed.
BUT
What about Neutrino oscillations? Neutrino's are said to change from electron neutrino --> tau neutrino --> muon neutrino, and so on. In order for these oscillations to happen, the neutrino must experience time, because these oscillations are time dependent. But we also know due to Relativity that time stops when you travel at c. If time was "stopped" for a neutrino, how can it oscillate?
Has this dilemma been answered already, and I have not done enough research?
Thanks in advance!
Where?
"Close to the speed of light" is not "at the speed of light".
Nearly the same, which is a completely different statement. The difference is too small to observe it with current experiments.
"In the early 1980s, first measurements of neutrino speed were done using pulsed pion beams (produced by pulsed proton beams hitting a target). The pions decayed producing neutrinos, and the neutrino interactions observed within a time window in a detector at a distance were consistent with the speed of light. This measurement was repeated in 2007 using the MINOS detectors, which found the speed of 3 GeV neutrinos to be 1.000051(29) c at 68% confidence level, and at 99% confidence level a range between 0.999976 c to 1.000126 c. The central value is higher than the speed of light and is consistent with superluminal velocity; however, the uncertainty is great enough that the result also does not rule out speeds less than or equal to light at this high confidence level" -wiki on neutrinos
so what is the speed?? is it close to light or what?
mfb said:
Where?
"The same observation was made, on a somewhat larger scale, with supernova 1987A (SN 1987A). 10-MeV antineutrinos from the supernova were detected within a time window that was consistent with a speed of light for the neutrinos. So far, the question of neutrino masses cannot be decided based on measurements of the neutrino speed." - wiki on neutrinos
Im not paying any attention to claims that neutrinos can travel faster than C, I know all those claims are miss calculations, and have since been proven wrong, so you don't need to bring that up.
With neutrino masses of the order of some milli-electron volt and neutrino energies of some MeV, the neutrino speed is about c*(1-10-18) or 0.999999999999999999 c.
SN1987 A was about 150,000 light years away, the sub-luminal speed corresponds to a time difference of the order of some microseconds.
No experiment has the sensitivity to see that small deviation from c, even if the deviation is crucial for mixing.
ok, thanks! So basically, it comes down to: We know that neutrino's don't travel at c, but our experiments don't have the sensitivity to tell how close to c neutrino's are traveling...slightly un-settling
I believe the general consensus at this point is that neutrinos do have mass. They are almost massless, and travel at a velocity very near C. But as you mentioned, the fact that they oscillate between flavors implies V<C. Although this is the generally accepted stance, there are apparently types of Lorentz-violations in some quantum gravity theories that could allow for neutrino velocity at or above C. My understanding (someone correct me if I'm wrong), is that they aren't very viable at this point (in the sense of being testable/falsifiable), but you might find them interesting nonetheless: http://en.wikipedia.org/wiki/Lorentz-violating_neutrino_oscillations#General_predictions
Right.
And without a method to produce collimated low-energy neutrinos or without very distant supernovae, I don't expect changes in that respect.
Direct mass measurements (beta decay) could measure the electron neutrino mass, and mixing experiments can give mass differences.
So, do gamma ray flashes emit neutrinos?
http://arxiv.org/abs/0907.2227
In none of the three time windows do we find a deviation from the background-only hypothesis.
The bad news: If there are neutrinos, they are even more high-energetic, and they can be produced at a different time.
  • · Replies 52 ·
