Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
Go Back   Physics Forums > Physics > Classical Physics
Reply
image Does a state function be multi-valued function Share It Thread Tools Search this Thread image
Old Feb23-05, 02:04 PM       Last edited by mpv55; Feb23-05 at 02:18 PM..            #1
mpv55
mpv55 is Offline:
A thermodynamic state function should be single valued function of independent varibles.
In case of steamtables of pure water, there is same entahlpy (U=2000 kJ/kg) at temperature T1=700K and pressure P1=63.458 MPa, and at T2=700K and P2=456.356 MPa. Thus U is a multiple valued function for pure water. How it can be explained with the basic laws of thermodynamics.
Old Feb23-05, 02:16 PM                  #2
dextercioby
dextercioby's Avatar
dextercioby is Offline:
Recognitions:
Homework Helper Homework Helper
The temperature is the same...?Anyway,it doesn't really matter.Enthalpy is denoted traditionally in thermodynamics by H,BTW...
So what is the problem...?
Daniel.
P.S.It's a REAL gas...
Old Feb23-05, 04:34 PM                  #3
mpv55
mpv55 is Offline:
Yes, enthalpy is generally represented by H. Let us read H for U.
Thermodynamics laws are applicable to all systems, real or ideal.
If we consider T and H as independent variables, it is impossible to predict the right value of P. The meaning of two values of P is that P is not an exact solution. This way- thermodynamics is not an Exact Science. Everyone knows that thermodynamic is an exact science, therefore the two values of P in the above situation are incorrect.
Let us further exemplify the above situation. We have a container filled with water at T=700 K and P=63.485 MPa. Since there is same H (2000 kJ/kg) for P= 63.458 MPa and 456.356 MPa at T= 700 K, it means we can pressurize (from 63.458 to 465.356 MPa) the container without any work. In other words, we can increase the pressure in a system of constant V and T without doing any work. If it is possible, we can develop a Carnot cycle to solve the world energy problem with no expense.
If a state function has multiple values, either the definition is incorrect or the data.
Thus the values of enthalpy are incorrect in steamtables.
Old Feb23-05, 04:44 PM                  #4
dextercioby
Recognitions:
Who said the volume is kept constant...?
Daniel.
Old Feb23-05, 06:15 PM                  #5
mpv55
mpv55 is Offline:
Let us keep is simple. A state function can have multivalues or not.
Old Feb23-05, 07:16 PM                  #6
Bystander
Bystander is Offline:
Recognitions:
Certainly.
Old Feb24-05, 02:45 AM                  #7
dextercioby
Recognitions:
Yes,u may want to check again the exact wordings of the principles in CTPCN formulation of the equilibrium thermodynamics.
Daniel.
Old Feb24-05, 10:12 AM                  #8
mpv55
mpv55 is Offline:
Any two state variables should define completly the pure system of constant mass. You can read any book on thermodynamics.
Old Feb24-05, 10:26 AM                  #9
mpv55
mpv55 is Offline:
Adjust add "in a phase of a pure system of constant".
"Nothing is more practical than a good theory"
Does it say something to you!
Old Feb24-05, 12:35 PM                  #10
dextercioby
Recognitions:
So what,what does my signature have to do with anything...?
Daniel.
Old Feb24-05, 01:30 PM                  #11
mpv55
mpv55 is Offline:
Dear Daniel:
If someone signs the quotation, he knows about the theory and donot write any comments without thinking.
The Gibbs phase rule is given in all the books, there is no need to cite any particular book.
Best wishes
Mahendra
Old Feb24-05, 06:57 PM                  #12
kanato
kanato is Offline:
State variables have to be single valued. The Gibbs-Duhem relation relies on this. If they weren't single valued, then a closed path on a state diagram could result in a change of the state variable.. that is the value of the variable would be path-dependent, which is the definition of something that is not a state variable, but a process variable.
Old Feb25-05, 10:12 AM                  #13
mpv55
mpv55 is Offline:
Yes, you are right. A state function has to be single valued function. It is a definition or based on the some relation. It is not the question, the question is that the steam Tables for pure water which is published in a NIST and AIP journal, J. Phys. Chem. Ref. Data, 2000, has multiple values for U, H and G.
It is really amazing the institutes producing standards for whole scientific community, do not know (or do not accept) that a state function should be single valued function.
Old Feb25-05, 10:39 AM                  #14
dextercioby
Recognitions:
Instead of wondering how & why this was possible,why don't u write a mail to them and tell them they're deadly wrong...
Daniel.
Old Feb25-05, 12:48 PM                  #15
mpv55
mpv55 is Offline:
I wrote an article on it to demonstrate the problem with the steam tables. Similarly, I proposed a method to measure the properties of water (liquid) correctly. I have big discussion the editor of JPCRD and the authority.
Their reply is that a state function can have multiple values. So, the steam tables of water has no problem.
If anyone is interested in reading it. I can send a copy. Just send me your email. my email is mahendra@iie.org.mx
If the thermodynamic properties of water are incorrect, there is problem in understading the natural processes on the earth.
image image
Reply
Thread Tools
Similar Threads for: Do a state function be multu-valued function
Thread Thread Starter Forum Replies Last Post
complex-valued function & derivative davedave Calculus & Analysis 0 Apr28-08 01:30 AM
arc length of vector-valued function; am I starting right? RogerDodgr Calculus & Beyond 5 Mar15-08 04:11 PM
What is a function of state? Von Advanced Physics 1 Dec22-07 06:56 AM
some doubts on state function kthouz Classical Physics 2 Sep6-07 11:12 AM
What is the function of the state? Smurf Politics & World Affairs 70 Jul28-07 10:39 AM
Powered by vBulletin Copyright ©2000 - 2010, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
