| New Reply |
What is the lever rule in a Txy diagram |
Share Thread | Thread Tools |
| Oct26-12, 12:46 AM | #1 |
I dont understand what the lever rule is on a Txy or Pxy diagram
I know that when you are given a mole compostition of said component, you go up to whatever temp or pressure is given to see the compositions. but, if it is inside the 2 lines of vapor and liquid, you use the lever rule. can someone plz explain this? thank you |
| Nov4-12, 03:50 AM | #2 |
bump
| New Reply |
| Thread Tools | |
Similar Threads for: What is the lever rule in a Txy diagram
| Deriving Bending Moment Diagram from Shear Force Diagram. Interesting Observation | Mechanical Engineering | 12 | ||
| Lever rule, help needed asap | Materials & Chemical Engineering | 1 | ||
| Lever question when lever is angled | Classical Physics | 1 | ||
| Is the Loedel Diagram a Special Case of the Minkowski Spacetime Diagram? | Special & General Relativity | 11 | ||
| Difference between Block diagram, Flowsheet and Flow diagram | Engineering Systems & Design | 1 | ||
