How Do You Calculate the Volume of Mountains and Polluted Air Around a City?
The discussion revolves around calculating the volume of mountains represented by the function y = -x^2 + 6x - 8, which is to be rotated around the y-axis, and the volume of polluted air, which involves the same function but requires rotation around either the x or y axis. Participants explore the implications of these rotations and the integration methods involved.
  • Mixed
  • Participants discuss using the cylindrical shell method for the first part and the disk method for the second part. There are attempts to express the function in terms of y and concerns about the limits of integration and the nature of the parabola.
Some participants have provided guidance on sketching the function and considering the regions for integration. There are ongoing questions about the correct limits for integration and the implications of using different axes for rotation. The discussion reflects a lack of consensus on the approach for the second part, particularly regarding the interpretation of the function and the integration setup.
Participants note the complexity of the problem due to the inverted parabola and the need to clarify the area of interest for integration. There are mentions of potential issues with negative values arising from the calculations, which contribute to the confusion in determining the correct approach.
mr3369
the function is y = -x^2+6x -8
suppose a city is surrounded by a ring of mountains and these mountains can be illustrated by rotating the above function around the y-axis. Find the volume of the Earth that makes up these mountains.
Suppose the city suffers from air pollution and wants to build a system to reduce this air pollution. However, in order to do so, it needs to find the volume of polluted air. This volume is the region between the y-axis and the function, rotated about either x or y axis. The picture for the polluted air is attached.
For the first part of finding the volume of earth, I integrated the function, using the cylindrical shell method. And I got the answer as 8 pi.
I used the radius as r = x, height as h = -x^2+6x -8,
So I integrated 2pi*r*h, from 2 to 4 which are the x intercepts.
For the 2nd part, I made the function in terms of y, So first I did completing the square and got y=-(x-3)^2 +1
So that gives me x = sqrt(1-y) +3
I used x as the radius, and using disk method , revolved the function around the y-axis.
So radius = sqrt(1-y) +3 ,
Then i integrated pi(r^2) from 0 to 3.
However, my answer gives me root(-2) which isn't possible. So I am stuck in this 2nd part.
Best way is to sketch the function first ... then shade the region to be integrated.
http://en.wikipedia.org/wiki/Solid_of_revolution
For the second part ... you may have to divide the region up into parts you can integrate over and add op the bits. Start out putting it as x(y) if you like, or you can figure a way to find the volume that is not part of what you want and subtract it off a greater volume that includes both.
You might want to check the range again. What are you integrating wrt?
I don't think I explained myself properly last time - I'll revisit:
x or y axis?
Anyway - the area of interest is between the line ##x=0## and the curve ##y=-x^2+6x-8## ... however: y(x) is an inverted parabola ... so for a particular value of y there are two possible values of x. y(x) also has a maximum - so there is an upper limit to any integration along the y axis.
Rotating this shape about the y-axis should create a trumpet-shape with the point at y=y(0) (if the inner surface is the one intended). It is unclear what would be intended by using the outer surface; nor by rotating about the x-axis, since y(x) extends above and below it. That picture of the pollution would have been handy.
This is why I urged you to sketch the situation.
What about the negative square-root: does it make a difference? Which side of the parabola is determining the length of the radius?
To do the method of disks - you are thinking of a horizontal disk, thickness dy, centered at (0,y), with radius x(y) so the volume of the disk at y is ##dV=\pi x^2(y)dy##. The trick is to get the correct x(y) and the correct limits for the integration.
How did you choose those limits?
  • · Replies 20 ·
