What is the current through the wire?
  • Thread starter Thread starter thisisfudd
    Current Wire
The discussion revolves around a problem involving a wire composed of two different materials, copper and aluminum, with a specified voltage difference applied across it. Participants are exploring the calculations of resistance and current in a series circuit, as well as the voltage drops across each segment of the wire.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • The original poster attempts to calculate the total resistance and current through the wire using resistivity values and Ohm's Law. Some participants question the application of current in series components and seek clarification on the relationship between current and voltage in this context.
Participants are actively engaging with the problem, with some providing corrections and clarifications regarding the behavior of current in series circuits. There is an acknowledgment of the need to apply Ohm's Law to determine voltage drops across each wire segment, indicating a productive direction in the discussion.
There is a mention of a lack of clarity in the original poster's textbook regarding the effects of current in series components, which has prompted further inquiry into the topic.
thisisfudd
Hi,
I'm pretty sure I did this right but it seemed abnormally easy so I wanted to check.
A 10-m length of wire consists of 5.0 m copper followed by 5.0 aluminum, both of diameter 1.0 mm. A voltage difference of 85 mV is placed across the wire. What is the total resistnace (sum) of the two wires? What is the current through the wire? What are the voltages across the alumnium part and across the copper part?
FYI Resistivity of copper = 1.68E-8, resistivity of aluminum = 2.45E-8
So for the first question I calculated the two resistances and added them using R = p (L/A), where that p is really a rho (resistivity)
I got Rcopper part = .11 = 1.68E-8 x 5.0 (pi x (5E-4)^2)
and Raluminum = .17 (calculated the same way, except with the rho of aluminum
Added together = .28
Then, for current I used V=IR so I = .3
And finally, I calculated I = .39 for copper and .25 for aluminum using V = IR again.
Is this really this simple?
nope, "And finally, I calculated I = .39 for copper and .25 for aluminum using V = IR again"
Is wrong. Look into how current is effected in serial components.
The rest looks good enough for government work.
Hi,
I looked in my book and it doesn't say how current is affected in serial components. Is it proportional to the individual resistivity?
Recall that electric current is the flow of electrons. An Amp is defined as a fixed number of electrons flowing per second. Now assume that you have a wire with x Amps of current flowing. If you were able to watch them in any given second you would see x electrons per second pass through a cross section of the wire. Now if you were to watch an adjacent cross section you must see the same number of electrons pass, since you neither lose nor gain electrons at any point. You can apply this logic to every point in the series circuit to conclude that the current must be constant at all points of a wire.
Oh, wow, that makes total sense. Looking back at the question, I was supposed to do something with voltages. I am not sure I know whether the same would hold true for voltage that does for current?
You now know the current in the wire. You also know the resistance in each section of the wire, Apply Ohms Law to each type of wire to find the voltage drop. You should be able to opserve the relationship with the total voltage.
Sorry Integral, I'm an idiot and figured that out about a nanosecond after I posted. Now my stupidity is out there for all the world to see.
Fudd
  • · Replies 17 ·
