Planck Photon: Unifying Principle at the Dual Planck Energy Threshold
  • Context: Graduate
  • Thread starter Thread starter Orion1
    Photon Planck
The discussion revolves around the concept of a "Planck Photon" and its implications at the dual Planck Energy threshold, exploring whether such a photon can exist and what unifying principles might arise from its interactions. Participants delve into theoretical aspects, potential particle decay processes, and the relationship between Planck mass and conventional particles.
  • Some participants question the existence of a "Planck mass" particle, with varying opinions on its implications and stability.
  • There is discussion about whether a concentration of energy at the Planck scale could lead to black hole formation.
  • Participants propose that a "Planck mass" could exist in a particle-sized form, but debate the nature and classification of such a particle.
  • One participant suggests that a Planck mass would likely obey macroscopic laws, while others argue it is fundamentally a quantum entity.
  • The energy of a Planck Photon is discussed, with questions about its origin and the feasibility of reactions involving such high-energy photons.
  • Some participants express confusion regarding the scale of Planck phenomena, questioning the relationship between mass, size, and energy.
  • There are inquiries about the decay products of high-energy photons and the potential for them to decay into multiple quantum particles.
  • Theoretical limits on photon energy are mentioned, with references to existing observations and the implications for particle physics.
Participants do not reach a consensus on the existence or implications of a "Planck mass" particle, and multiple competing views remain regarding the nature of Planck phenomena and the feasibility of high-energy reactions.
Limitations include unresolved assumptions about the stability of Planck mass, the definitions of particles at the Planck scale, and the implications of energy concentration leading to black hole formation. The discussion also reflects uncertainty about the relationship between quantum and macroscopic laws.
Readers interested in theoretical physics, quantum mechanics, and the implications of Planck scale phenomena may find this discussion relevant.
Orion1
[tex]\gamma (E_1) \rightarrow e^+ + e^- \; \; \; E_1 = 2 m_e c^2[/tex]
[tex]\gamma (E_2) \rightarrow p^+ + p^- \; \; \; E_2 = 2 m_p c^2[/tex]
[tex]\gamma_p (E_3) \rightarrow m_p^+ + m_p^- \; \; \; E_3 = 2 c^2 \sqrt{\frac{\hbar c}{G}}[/tex]
[tex]E_n[/tex] - photon energy
[tex]\gamma_p[/tex] - Planck Photon
[tex]m_p^+[/tex] - Planck mass (matter)
[tex]m_p^-[/tex] - Planck mass (anti-matter)
Given that reaction 1 and 2 are possible when energically feasable, is reaction 3 possible if energically feasable?
Can a 'Planck Photon' exist at the dual Planck Energy threshold?
If possible, what type of unifying principle would such a reaction represent?
The question is, if such concentration of energy in a small region of space will black hole itself out.
Is there such a thing as a "Planck mass" particle?
I've never heard of one. I mean Planck's mass is heavy on the atomic scale. I don' t think there is. Maybe I'm wrong...
Planck Particle...
I suppose a hypothetical formula is required to determine if a Planck mass is 'stable'. What is the equation formula that could determine Planck mass 'stability'?. Is Planck mass 'stable'?
A 'particle' sized Planck mass can exist, but a Planck mass 'particle' cannot exist?
If a Planck mass 'particle' can 'exist', what family and class of known conventional particles would it most closely resemble?
Which conventional 'particle' does it most closely resemble?
[/color]
[/color]
I'm abit confused with what your asking, but isn't the Planck mass around the mass of a flea? I'm saying that there is no atomic particle that has such as mass. Am I wrong?
I think what DB is trying to say is that the Planck mass is about
[tex]10^{-8} kg[/tex]
while atomic masses are on the order of
[tex]10^{-26} kg[/tex]
So something of Planck mass would probably obey macroscopic laws. And talking about it as a fundamental particle is a little odd.
For arguments sake the Energy of the Planck Photon mentioned above is about
[tex]10^{10} GeV[/tex]
Where would a photon of this energy come from?
I'm confused. I thought "plank scale" stuff was supposed to be really small. So is a plank "thing" the smallest quantity of that "thing" you can measure/have?
Entropy, the point is that mass is inverse of distance, via x=h/mc
So Planck stuff has small size, high mass, high energy. Or, the most energy (mass) you put, the more resolution you have. Electron microscopes having more resolution than optical microscopes &c.
Off topic, but what happens when an EM wave (or photon or whatever) has a frequency wayyyyy beyond the gamma ray and radiowave region. What would it be? What kinda properties would it have?
the highest photon observed is ~10^20 eV, and theoretical physics set no upper limit on energy of photon...
Do you have a reference for this?
Thanks.
Planck Particle...
If Planck mass obeys macroscopic laws, and only microscopic particles obey De-broglie waves, then it must be stated that:
Macroscopic Law:
[tex]r_p > \overline{\lambda_p}[/tex] - Planck radius greater than Planck-De Broglie wavelength
Microscopic Law:
[tex]r_p = \overline{\lambda_p}[/tex] - Planck radius equals Planck-De Broglie wavelength
Planck Wavelength solution:
[tex]\overline{\lambda}_p = \frac{\hbar}{m_p c} = \frac{\hbar}{c} \sqrt{\frac{G}{\hbar c}}[/tex]
[tex]\overline{\lambda}_p = \sqrt{\frac{\hbar G}{c^3}}[/tex]
[tex]\boxed{r_p = \overline{\lambda}_p = \sqrt{\frac{\hbar G}{c^3}}}[/tex]
Although Planck mass appears to be a macroscopic entity, it is in fact a microscopic entity which obeys quantum laws and therefore, is a quantum 'particle'.
- (see reference 2)
Maxwell's equations, which the derivatives describe all electromagnetic phenomena, do not describe any theoretical limit to a photon's energy, however given that photon energy is quantizised, a possible Maxwell energy solution is:
[tex]E_n = \frac{n \hbar}{\overline{\lambda} \sqrt{\mu_o \epsilon_o}}[/tex]
Given that there is no theoretical upper limit to photon energy and given that Planck mass IS a microscopic quantum particle, then reaction 3 listed above IS energetically feasible (possible).
A photon is an electromagnetic wave, and all electromagnetic waves obey the Principle of Superposition:
For two or more photons, the resultant wave function at any point is the algebraic sum of the wave functions of the individual waves.
Is reaction 1 possible through the Principle of Superposition constructive interference?
[tex]\psi (E_a)_{\gamma} + \psi (E_b)_{\gamma} = 2 \psi (2E_t)_{\gamma} \rightarrow e^+ + e^- \; \; \; E_a = E_b = m_e c^2[/tex]
[/color]
Reference:
http://galileo.phys.virginia.edu/classes/252/wave_equations.html
http://imagine.gsfc.nasa.gov/docs/ask_astro/answers/970412e.html
Sorry, I was asking for a reference for the 10^20 eV particle, I was trying the other day to find the value for the highest energy photon observed but couldn't find anything satisfactory. I would never disagree with the photon obeying quantum laws, but it would be interesting for it to decay into these huge rest mass particles that would essentially be classical in nature. I would guess that it (the extremely high energy photon) would decay into many "quantum particles" rather than 2 essentially classical ones. It would be interesting to probe this, though I know it wouldn't be energetically feasible in the near future.
Cheers
Oh, okay, I understand now. It's related to uncertainity.
Norman Normalization...
Based upon the Planck Photon threshold energy, what types of 'quantum particles' would be the expected 'particle' decay products?
What is the threshold energy for unification based upon the Standard Model?
Planck mass is the mass which is required to collapse a Planck size volume into a black hole. QM predicts that no smaller black hole can exist. GR has no such restriction, and predicts that smaller black holes can exist in spaces smaller than the Planck volume. Perhaps we will have an answer to this question if the new collider at CERN produces miniature black holes, as some physicists have predicted.
Sorry I must not have been thinking... a free photon has an infinite lifetime. It is a stable particle and does not have a preferred decay channel. See http://pdg.lbl.gov/ please. But if this was a virtual photon it would of course be constrained by the the conservation laws of the initial particles (ie electric charge, lepton number, etc). I am sorry but I do not understand your question about threshold energy of unification of the Standard Model. If you are asking at what energy is it projected that the strong and electroweak forces become indistinguishable, I believe it is believed this happens at about 10^15 GeV.
I would be good to note that this(grand unification energy) has (not yet) been tested but I think it is probable based on the unification of the weak and electromagnetic forces.
Please note my orginal post on the Planck energy above was wrong. I redid the calculation since I noticed that grand unification would happen way above the Planck energy and it should not, they should be close but unification is just below Planck energy.
[tex]E_p=\sqrt{\frac{\hbar c^5}{G}}=\sqrt{\frac{(1.05\times 10^{-34}) (3\times 10^8)^5}{6.67\times 10^{-11}}}=1.96\times10^9J=3 \times 10^{16} GeV[/tex]
Sorry about the mix up. I don't know where I got 10^10 GeV...
The 'Planck Energy' threshold is:
Planck Energy:
[tex]\boxed{E_p = \sqrt{\frac{\hbar c^5}{G}} = 1.956 \cdot 10^9 \; J = 1.221 \cdot 10^{19} \; GeV}[/tex]
The 'SU(5) Energy' threshold is:
[tex]E_{SU(5)} = 10^{15} \; GeV[/tex]
Reaction 3 in post#1 originates from a 'virtual Planck Photon' of dual 'Planck Energy' amplitude.
The difference between 'SU(5) Energy' and 'Planck Energy' is that at SU(5) Energy, strong and electroweak forces become indistinguishable. At the 'Planck Energy', the strength of the gravitational interactions of fundamental particles becomes indistinguishable from the strong and electroweak forces.
The 'Planck Energy' is the typical energy of a vibrating string in string theory.
Is a 'Planck Photon' a Gamma Photon?, or is a new classification required for the 'Orion1 Spectrum'?
What is the fundamental difference in wave function between a virtual photon and a free photon?
What is the fundamental difference in wave function between a virtual 'Planck Photon' and a fixed-ended vibrating string?
[/color]
Reference:
http://www.site.uottawa.ca:4321/astronomy/index.html#Planckenergy
http://www.valdostamuseum.org/hamsmith/SU5GUT.html
