How Do Friction and Centripetal Force Affect Motion on a Slide and a Rotor Ride?
The discussion focuses on calculating the coefficient of kinetic friction for a child sliding down a 29-degree incline and understanding the forces at play in a rotor ride. The child’s speed at the bottom is two-thirds of the speed if the slide were frictionless. The equations of motion are derived using energy conservation principles, specifically ΔK + ΔU = W_f = F_f d = μF_N l, where μ is the coefficient of friction. Additionally, the concept of reference frames is explored to explain the sensation of being pressed against the wall in a rotor ride.
  • Understanding of Newton's laws of motion
  • Familiarity with energy conservation principles in physics
  • Knowledge of friction coefficients and their calculations
  • Basic ability to draw and interpret free body diagrams
  • Calculate the coefficient of kinetic friction using the derived equations
  • Explore the concept of reference frames in physics
  • Study the dynamics of circular motion and centripetal force
  • Investigate energy conservation in inclined planes and friction scenarios
Students studying physics, educators teaching mechanics, and anyone interested in the practical applications of friction and centripetal force in real-world scenarios.
Vlyandra
I feel like there's not enough information to solve this:
A child slides down a slide with a 29 degree incline, and at the bottom her speed is precisely two-thirds what it would have been if the slide had been frictionless. Calculate the coeffieicnt of kinetic friction between the slide and the child.
Also, I can't explain why, in those "rotor-rides" at the carnival where you're spun around fast enough to overcome static friction and not slide down, why you feel like you're being pressed against the wall but you're really not. Any help would be greatly appreciated.
Welcome to the forums! :smile:
However in order to get help you need to SHOW US what progress you have made since we don't provide solutions we simply guide you along the way
ok first of all let's just assume that the child started to slide from rest
so then if there was no friction involved
[tex]\Delta K + \Delta U = 0[/tex]
calculate the velocity (use variables only)
the height change you used here is somehow related to the length of the slide itself
Now that you have a velocity 2/3 of this velocity is the velocity you will use in the next part
assume ther was friction
[tex]\Delta K + \Delta U = W_{f} = F_{f} d = \mu F_{N} l[/tex]
where L is the length of the slide
sub in what you have so far for the velocity (remember to square it!) you know the change in potential energy.
Draw a fre body body diagram of the child nad figure out the normal force and see what cancels out. Your answer should have no need for the mass or the length of the slide.
For the second problem, I'll give you a hint: You get pressed against the wall right? What kind a reference frame are you in? What kind of a reference frame is a person on the ground in? What is the difference? (Sorry for making it look all so obvious...but you still got to reason it yourself mate).
  • · Replies 19 ·
