Dirac Delta function |
Feb25-05, 01:27 AM
#1
Reshma is
Offline:
Can someone explain me the Dirac Delta function for the function:
Feb25-05, 02:37 AM
#2
James R is
Offline:
Your question doesn't seem to make sense. The Dirac Delta Function is always the same. It doesn't rely on any other function.
Feb25-05, 03:00 AM
#3
Reshma is
Offline:
I'm sorry, the given function is the Dirac delta function. Can someone explain it to me?
Feb26-05, 03:27 AM
#5
Reshma is
Offline:
Thanks for the link, Vivek. But it did not completely solve my problem. The proofs given in most texts are too mathematical. I need a more physical interpretation of the problem.
Feb26-05, 03:42 AM
#6
vincentchan is
Offline:
what is your question?
your question doesn't make sense at all?
Feb26-05, 03:53 AM
#7
himanshu121 is
Offline:
I believe You want to interpret its curl or div in terms of Dirac Delta Function
Feb26-05, 04:12 AM
#8
maverick280857 is
Offline:
Yes they are mathematical because of the very definition of DDF. Strictly, it is not a function but it is considered a function. If you want good physical interpretations of its applications, get a copy of Classical Electrodynamics by Griffiths and read the first chapter (I think its called mathematical preliminaries but I'm not very sure).
Hope that helps...
cheers
vivek
Feb26-05, 04:13 AM
#9
Gokul43201 is
Offline:
Perhaps you (Reshma) are asking for a proof that the charge (density) distribution that produces this field is a dirac-delta function (about the origin) ? The given field itself is not a dirac-delta.
Feb26-05, 06:09 AM
#10
dextercioby is
Offline:
Recognitions:
It can be proven really easily that the Green's function for an oO domain (R^{3}) for the Poisson equation:
 (1)
is:  (2)
And incidentally,the field,being the -gradient of the solution of (1),can be put in connection to (2)...
Daniel.
Feb26-05, 07:28 AM
#11
Reshma is
Offline:
Yes, you are right. I want an interpretation of the divergence of the given function.
Feb26-05, 07:30 AM
#12
Reshma is
Offline:
Hope that helps...
cheers
vivek
Yes I do have Griffith's book which has described the above function over a sphere using Green's theorem.
Feb26-05, 07:35 AM
#13
dextercioby is
Offline:
Recognitions:
You want the proof that the  is proportional (it's a "-1" the coefficient of proportionaliry,IIRC) to delta-Dirac...?
That's a pretty delicate matter.It's not really for physicists...Any book on PDE-s should have it,when discussing Laplace & Poisson equations.
Daniel.
Feb26-05, 08:01 AM
#14
Reshma is
Offline:
Daniel.
I am extremely sorry for stretching this thread this far
I only want to know the proof for:
With a little physical interpretation...
Feb26-05, 11:50 AM
#15
dextercioby is
Offline:
Recognitions:
That is something else...As u can yourself check...
Turning to the original question,i can add:except for the origin,where the fraction to whom you apply the diff.operator is not defined,the result is zero.However,as  is the Green function for the Poisson equation for R^{3},it can be shown that,in fact:
As for physical significance,please,check (as you probably already have) Griffiths' book.Or Jackson's...
Daniel.
Feb26-05, 01:57 PM
#16
kanato is
Offline:
everywhere, except the origin, where we have a point of non-differentiability.
By integrating over the volume of a sphere, and applying the divergence theorem, we see
independent of the radius of the sphere. Thus integration over any volume including the origin gives 4*pi, and any other volume gives zero. A function which satisfies this would be 4*pi times a delta function located at the origin. Thus,
