Choosing the Right Electric Generator for Your Living Room in the USA
  • Thread starter Thread starter biferi
    Generator
The discussion revolves around selecting an appropriate electric generator for powering devices in a living room setting, specifically in the context of potential power outages. Participants explore various types of generators, including battery-powered and hand-cranked options, and discuss their functionality and suitability for specific household needs.
  • One participant seeks clarification on how electric generators work, particularly regarding their amperage and voltage outputs in relation to household devices.
  • Another participant suggests considering an uninterruptible power supply (UPS) for short-term outages, while others mention the need for a generator with its own engine for longer outages.
  • Some participants discuss the feasibility of using hand-cranked generators and the limitations of battery-powered systems, particularly regarding duration and power output.
  • There is a mention of connecting a motor to a battery to generate electricity, with some participants explaining the principles of charging batteries and the role of inverters in converting DC to AC power.
  • Questions arise about the specifications of batteries, including amp hours and how they relate to the power needs of devices like TVs and lamps.
  • One participant expresses confusion about how a battery rated at 48 amp hours can supply varying amounts of current over different time periods.
  • Clarifications are provided regarding deep cycle batteries and their ability to be discharged and recharged multiple times, along with their expected lifespan and performance.
  • Another participant emphasizes the importance of prioritizing power needs during outages, suggesting that entertainment devices may not be as critical as heating or refrigeration.
  • There is a personal context shared about frequent power outages, framing the generator as a fun project rather than a necessity.
The discussion contains multiple competing views regarding the best approach to powering devices during outages, with no consensus reached on the ideal generator type or configuration. Participants express differing opinions on the practicality and efficiency of various solutions.
Participants discuss the limitations of different power sources, including the efficiency of inverters and the specific power requirements of household devices. There are unresolved questions about the optimal specifications for batteries and generators based on individual needs.
This discussion may be useful for individuals considering backup power solutions for home use, particularly those interested in the technical aspects of generators, batteries, and inverters in the context of power outages.
biferi
I live in the USA and was thinking about getting an Electric Generator just for my Livng Room.
So it could power my T.V. my DVD Player and my Lamp.
Now I know they have Electric Generators that have Battery Power some are Hand Cranked.
I just need to know some things first about how they work?
I know the Home Outlet has 120 Volts at 15 AMPs so 120 x 15 = 1,800 WATTs.
So my Living Room Outlet is giving 1,800 WATTs of Power and I know just because my T.V. is pluged into the Outlet it is not useing the whole 15 AMPs.
So if I got an Electric Generator and it gives 10 AMPs at 120 Volts would it not Power the T.V. because the T.V. is not useing 15 AMPs?
Or how does this whpole thing work?
Why do you want to generate power just to your sitting room? If you want to be covered for short term power cuts you might be able to fit UPSs where needed if you are talking about longer outages you need something with it's own engine.
I am Sorry this is what I ment.
If the Power goes out the only things I need to be powered is the Living Room
The Lamp The T.V.
The DVD Player
I know what UPs are you plug your Device into it and plug the UPs into the Outlet.
And the Outlet passes the power to the Device and at the same time it charges a Battery in the UPs.
So if you loss power the Device pluged into the UPs starts runing off the UPs Battery I get this.
But they do not last long and rundown.
I do not want to get a Gass powered on because I do not want to fill it and keep the Gass and it only has to power my Living Room.
So I thought they have maybe Hand Crank ones that you turn it by Hand for say 10 min. and they last for an Hour>
Well I did read this on how to make a Genarator.
Take a Motor with the Shaft sticking out and connect it to a Battery with the same Voltage as the Motor.
When you turn the Motors Shaft I know how this is working you are spining the Magnet inside the Coil of Wire and the Motor is making powor I get this.
So you are charging the Battery.
But not all Battories can be charged and you can only run something that uses what the Battory can supply.
http://www.ehow.com/how_5133500_build-hand-operated-electric-generator.html
I think what you are looking for is ether a UPS, or a battery with a inverter.
Part of my hurricane kit is a 1000 watt inverter and 2 deep cycle batteries.
http://www.harborfreight.com/1000-watt-continuous-2000-watt-peak-power-inverter-97047.html
The idea being that I can recharge the battery from the car.
Inverters are good for tv, fan, and some lights, most will not start even a small
refrigerator.
Well I read that you can Hockup a 9 Volt Car Battery to a 9 Volt Motter and when you turn the Motter Shaft the Magnet spins in the Coil to make Electric I get all of this.
And this will recharge the Battery.
And the Invert makes DC into AC but one thing.
The Living Room Outlets give 120 Volts not 9 Volts so how can I Hock the Battery up to say my TV or DVD Player?
The car battery is 12 volts DC, the Inverter has a 12 volt DC input, and a 120 volt AC output.
The inverter has normal 110v outlets on it.
Just plug you devices directly into the inverter.
Ok thanks for getting back to me but on thing is the 12 Car Battery 15 AMPs?
You actually want a deep cycle battery. something like this.
http://www.atbatt.com/product/24022.asp?utm_source=frog&utm_medium=cpc&utm_content=textlink-automotive-batteries&utm_campaign=frog1&utm_term=SRM-24&gclid=COnNtKaeu7MCFcKPPAodaF0AhA
84 amp hours.
84 amps times 12 volts is 1008 watts,
So you could run 1000 watts for about 1 hour, or 250 watts for about 4 hours.
They also make better deep cycle batteries, they just cost more.
Now I know ONE Amp is ONE big number of Electrons that will go past one point in one SEC.
And my Living Room Outlet gives 15 AMPs so this is 15 Coulombs of Electrons that will go past One point in One SEC.
But what I do not understand is Batteries are Rated as AMP Hours so when you say a 12 Volt Battery is 48 AMP Hours do you meen this.
The Battery will last for 48 Hours but how many AMPs does it supply?
48 amps for one hour or 1 amp for 48 hours.
LCD TV uses about 150 W or 1.25 amps.
Lamp, 60W or 0.5 amps.
DVD player 15W or 0.125 amps.
Total - about 2 amps.
Inverters are not very efficient but you should get 24 hours using one and a 84 A/h battery.
OK just one thing.
You tell me a 48 Amp Hour Battery will give 48 Amps for 1 Hour I get this.
But then you say it can also give 1 Amp for 48 Hour.
If it can give 48 Amp for 1 Hour how can it also give 1 Amp for 48 Hour how do you bring the Amp down to 1 Amp?
Or am I missing something?
V=AxR
Volts is constant, so current depends on resistance. As resistance increases, amps decrease. So, by selecting a low resistance (e.g starter motor) I pull a lot of amps. By selecting a high resistance (parking lights) I only pull 1 or 2.
W=VxA Re-arranged, V=W/A
Again, volts is constant. So current depends on watts too. In this case, as watts increase so do amps. A 3 kW washing machine pulls more amps than a 60 W light bulb.
Thank you I now understand how they will work.
Now If I get a 12 Volt 48 Amp Hour Car Battery you tell me I should get a Deep Cycle Battery.
What is a Deep Cycle Battery?
A Deep Cycle Battery is
a lead-acid battery designed to be regularly deeply discharged using most of its capacity
A deep-cycle battery is designed to discharge between 50% and 80% depending on the manufacturer and construction of the battery. Although these batteries can be cycled down to 20% charge, the best lifespan vs cost method is to keep the average cycle at about 50% discharge,[1] as there is a direct correlation between depth of discharge on the battery and the number of charge and discharge cycles it can perform.
Ok tell me if I have everything down Right?
If I have a Deep Cycle 12 Volt 48 AMP Hour Car Battery it can be Drand and Re Chared over and over and last longer?
If I take a Deep Cycle 12 Volt 48 AMP Hour Car Battery and connect it to an Inverter the Output will be 120 VAC and give 48 AMP for 1 Hour? And with 48 AMPs for 1 Hour I can run my TV and DVD Player and Lamp in the Living Room?
biferi – where do you live? Is it cold there? Here where I am it is cold, so the main reasons to have a generator for power outages are to keep the furnace running (controls and circulating pump or fan) and to run the refrigerator (so the meat doesn’t spoil). Compared to these, a DVD player and a TV are small loads. So, just keep your priorities in the right order! Also, if you have a long power outage, there is no sense in watching TV because they will just say over and over, “the power is still out and it is cold.” You knew that already! If you want to watch DVDs maybe get a portable player and some batteries for it, that will be cheaper than the big battery and inverter discussed above.
Soory I live in the USA but this is more of a Fun Project for me.
You see we Lose Power even if it Rains a little.
So I just thought it would be nice to have a GEN for watching T.V. and to plug the Lamp in.
So when you Buy an Inverter it will Output 120 VAC but what will the AMPs be?
What I mean is if I have a 12 Volt 48 Amp Hour Batter the Inverter will output 120 Volts but will it just pass the Current through as is?
So I still will get 48 Amp for 1 Hour?
Most auto parts stores and walmart will have deep cycle batteries.
Thanks for getting back to me.
This is my Project.
I will have a 12 vdc 48 Amp Hour Barttery and a 12 vdc Motter all in Parallel.
Now the Battery will be connected to the Inverter to give me 120 VAC and when the Battery goes down I can Hand Turn the Motter Shaft to Re Charge the Battery.
Ok this is what I would like to try just for fun.
Take a 12 Volt 48 Amp Deep Cycle Car Battery and hoock it up to an Inverter.
Then I can run my TV Lamp and so on off it just little things.
Then hoock up a 12 Volt Moter with the Shaft sticking out and connect it to a handel. And then when the Battery goes down just Crank the Handel to turn the Motter Shaft and this will re chartge the Battery.
Will this work?
Sure, but you'd have to have to crank literally all day to recharge it. Even if you hooked it up to a bike so you could use your legs (much stronger than your arms) it would take several hours.
Also, no one corrected you before, but you seemed to think that you could provide 48 Amps for 1 hour at 120 V. The 48 amp-hours is at 12 volts. If you multiply the voltage by 10, the amp-hours are cut by a factor of 10 (4.8 amp-hours).
Thank you for all the infor.
Can I make a small GEN. just to run my Lamp and TV and DVD Player?
Sure, depending on what you use to power the generator.
