D Meson Decay: Neutral D-Meson Branching Ratios
The discussion centers on the branching ratios of neutral D-meson decays, specifically comparing three decay channels: D → K⁻ + π⁺, D → π⁺ + π⁻, and D → K⁺ + π⁻. Participants explore the implications of weak interactions versus electromagnetic interactions in these decay processes.
  • One participant suggests that the decay D → K⁻ + π⁺ has the highest branching ratio due to non-cross generation mixing, while questioning why D → π⁺ + π⁻ is not more likely despite the possibility of photon involvement.
  • Another participant emphasizes that weak transitions must occur, noting that leading order processes do not involve photons, which would be a higher order effect in quantum electrodynamics (QED).
  • A participant raises a concern about the production of two pions through virtual photons and questions why this would not yield a larger branching fraction compared to weak interactions.
  • Discussion includes the role of CP conservation and the implications for the decay processes, with one participant suggesting that intermediate photons are virtual and quarks must be produced.
  • Another participant points out that D⁰ → γγ has not been observed yet, indicating an upper limit on its branching fraction and discussing the competition between weak and electromagnetic interactions.
  • Branching fractions for various decay channels are mentioned, with specific values provided for D⁰ → π⁺ + π⁻ and D⁰ → K⁺ + K⁻, highlighting the dominance of powers of the CKM matrix element λ in these processes.
  • There is a mention of D⁰ mixing and upcoming news from HCP2012, indicating ongoing research and developments in the field.
Participants express differing views on the likelihood of various decay channels and the role of virtual versus real photons in these processes. The discussion remains unresolved regarding the relative branching ratios and the implications of CP conservation.
Limitations include the dependence on the definitions of weak and electromagnetic interactions, as well as the unresolved nature of certain decay processes and their branching fractions.
kokolovehuh
Hi all,
I have a question regarding to the branching ratio of neutral D-meson decay.
Give three decays:
1. D --> negative kaon + positive pion
2. D --> positive pion + negative pion
3. D --> positive kaon + negative pion
The one with highest branching ratio is 1. due to its non-cross generation mixing. However, my question is: why isn't 2 more likely since D-meson can decay into two photons and split into two pairs of quarks? It's because Intermediate photons are involved with EM interactions, which dominate over weak interactions (1 and 3 b/c they don't conserve strangeness).
Thanks :\
O.
The first thing to notice is you MUST have a weak transition. So the leading order will be a weak-tree diagram, with NO photons (as that would be next order in QED).
These are the weak transitions right?
c-> s + dbar u
ubar-> ubar
= K- pi+
c->d + dbar u
ubar-> ubar
= pi- pi+
c->d + sbar u
ubar-> ubar
= K+ pi-
c->s + sbar u
ubar -> ubar
= K+ K-
So in this order we have:
Vcs Vud ~ 1 * 1
Vcd Vud ~ (-lambda) * 1
Vcd Vus ~ (-lambda) * (lambda)
Vcs Vus ~ 1 * (lambda)
where lambda ~ 0.2257
I imagine this is the first reason why they're ordered thusly.
Yea, I see how this works like that.
But as I mentioned before, since 'positive pion + negative pion' can be produced through two photons why wouldn't it be produced more often than the ones from weak interaction?
Also a stupid question, when do you take the Vxx to be negative? Vxx = any element in KM matrix
If you want #2 to proceed via two virtual photons, why would you not have an even larger branching fraction into two real photons?
Vanadium 50, it's probably because of some CP conservation; so we have pions as products. This is why the intermediate photons are only virtual and we need quarks to be produced.
No, that's not your problem. A D0 is not in a CP eigenstate.
##D^0 \to \gamma \gamma## is not observed yet, with 2.5*10-5 as upper limit on the branching fraction (~1/5 of the WS ##D^0 \to K^+ \pi^-## BF). It needs weak and electromagnetic interaction at the same time. Why do you want photons in the diagram? Gluons would do the same, just with a stronger coupling. It cannot compete with the singly cabibbo suppressed tree diagram, however.
If you look at the -> KK, Kpi, pipi branching fractions (and similar -> K pi pi pi, -> K K K pi and so on), powers of lambda dominate.
At least roughly:
BF ##D^0 \to \pi^+ \pi^-## is 0.14%
BF ##D^0 \to K^+ K^-## is 0.40%
And of course there is mixing... HCP2012 will have some news about that (14. November).
mfb, it does make whole lot more sense now; thanks a lot
btw Vanadium 50, (correct me if I'm wrong) you don't need a particle decay to be in CP eigenstate to conserve charge conjugation/parity in any non-weak interactions.
I was trying to point you in the right direction - or at least away from the wrong one.
  • · Replies 31 ·
  • · Replies 0 ·
  • · Replies 29 ·
11K
