Proof of Induction: Homework Statement
  • Thread starter Thread starter mtayab1994
    Induction Proof
The discussion revolves around a sequence defined by \( U_{n}=\frac{n^{2}}{2^{n}} \) and its properties, particularly focusing on the ratios \( V_{n}=\frac{U_{n+1}}{U_{n}} \). Participants are tasked with proving various statements about the convergence of the series \( S_{n} \) formed by summing the terms of the sequence starting from \( n=5 \) and exploring the implications of these ratios.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the limit of the ratio \( V_{n} \) and its implications for the sequence \( U_{n} \). There are attempts to establish bounds for \( V_{n} \) and to find the smallest \( N \) such that certain inequalities hold. Questions arise about the validity of specific steps in the proofs and the application of induction.
Some participants have successfully addressed parts of the problem, specifically the initial limits and inequalities. However, there remains uncertainty regarding the induction steps and the implications of the established bounds. Multiple interpretations of the induction process are being explored, with some participants questioning the assumptions made in their reasoning.
Participants are working under the constraints of proving statements by induction for natural numbers greater than 5. There is an emphasis on ensuring that the base case and inductive steps are correctly established, with some confusion noted regarding the starting point for the induction.
mtayab1994
Let [tex]U_{n}=\frac{n^{2}}{2^{n}}[/tex] for every n in N
1) For every n>0 let [tex]V_{n}=\frac{U_{n+1}}{U_{n}}[/tex]
a) Prove that [tex]\lim V_{n}=\frac{1}{2}[/tex]
b) For every n>0 prove that: [tex]V_{n}>\frac{1}{2}[/tex]
c) First the smallest natural number N such that : [tex]n\geq N\Rightarrow V_{n}<\frac{3}{4}[/tex]
d) Conclude that [tex]n\geq N\Rightarrow U_{n+1}<\frac{3}{4}U_{n}[/tex]
2) We want to show that [tex](S_{n})_{n\geq5}[/tex] is convergent such that:
Sn=U5+U6+U7+...+Un
a) Prove by induction that for every natural number greater than 5: [tex]U_{n}<(\frac{3}{4})^{n-5}U_{5}[/tex]
b) Prove also by induction that for every natural number greater than 5:
Sn≤[1+(3/4)+(3/2)^2+...+(3/4)^(n-5)]U5
c) Conclude that Sn≤4U5 for every n≥5
3) Prove that [tex](S_{n})_{n\geq5}[/tex] is monotone increasing and conclude that it is convergent.
Solved 1) a and b and stuck on c and d.
For number 2-a I showed that U5≤U5 and I need to know how to show that Un+1≤(3/4)^n-4U5.
I have no idea on b and c and number 3.
Thanks for any help before hand.
mtayab1994 said:
Let [itex]\displaystyle U_{n}=\frac{n^{2}}{2^{n}}[/itex] for every n in N
1) For every n>0 let [itex]\displaystyle V_{n}=\frac{U_{n+1}}{U_{n}}[/itex]
a) Prove that [itex]\lim V_{n}=\frac{1}{2}[/itex]
b) For every n>0 prove that: [itex]V_{n}>\frac{1}{2}[/itex]
c) First the smallest natural number N such that : [itex]n\geq N\Rightarrow V_{n}<\frac{3}{4}[/itex]
d) Conclude that [itex]n\geq N\Rightarrow U_{n+1}<\frac{3}{4}U_{n}[/itex]
2) We want to show that [itex](S_{n})_{n\geq5}[/itex] is convergent such that:
Sn=U5+U6+U7+...+Un
a) Prove by induction that for every natural number greater than 5: [itex]\ \ U_{n}<(\frac{3}{4})^{n-5}U_{5}[/itex]
3) Prove that [itex](S_{n})_{n\geq5}[/itex] is monotone increasing and conclude that it is convergent.
For C:
What is [itex]\displaystyle V_{n}\ ?[/itex]
Do you see how to get the answer to D from the answer to C ?
SammyS said:
For C:
Vn=(Un+1)/(Un) And I counted the difference Vn-(3/4) I got a polynomial of -n^2+4n+1 over 8n^2 and found that the answer N=5 is that correct??
mtayab1994 said:
Vn=(Un+1)/(Un) should i count the difference of Vn-(3/4).
Of course. How about the result after plugging in the specific expressions for Un and Un+1 ?
Well since Vn=(Un+1)/Un and we proved that Vn<3/4 then (Un+1)/Un<3/4 therefore:
Un+1<(3/4)Un. By the way in my previous quote i found N=5.
Yes, 5 is correct.
#2. (a) says:
Prove by induction that for every natural number greater than 5: [itex]\displaystyle \ \ U_{n}<\left(\frac{3}{4}\right)^{n-5}U_{5}\ .[/itex]​
So show that it's true for n=6, not n=5 .
So, assume that [itex]\displaystyle \ \ U_{k}<\left(\frac{3}{4}\right)^{k-5}U_{5}\[/itex] is true for some k ≥ 6 . From that assumption, show that [itex]\displaystyle \ \ U_{k+1}<\left(\frac{3}{4}\right)^{(k+1)-5}U_{5}\[/itex] is true.
SammyS said:
Yes, 5 is correct.
#2. (a) says:
I'm sorry it is greater than or equal to 5. So for n=5 we get U5≤U5 and that's true.
So we assume Un≤(3/4)^(n-5)U5 and we show that Uk+1≤(3/4)^(k-4)U5 is true.
Ok this is what i got :
[tex]U_{k+1}-(\frac{3}{4})^{k-4}U_{5}=\frac{32(k+1)^{2}-((\frac{3}{4})^{k-4}(25\cdot2^{k+1})}{25\cdot2^{k+1}}[/tex] and i assume that that is negative because n^2≤2^n so therefore (n+1)^2≤2^(n+1) . So we get the numerator to be less than or equal to zero and the denominator is positive so the difference is negative. is that correct??
Is that the result of using induction?
No it's not i did a different way i added the left side and the right side from k=5 to k=n-5 and then I added the results from the left hand side and the left hand side and i found that Uk+1≤(3/4)^(n-5)U5. I've also solved all of the other ones as well. Thanks for you help.
The instructions were very clear regarding solving by induction.
  • · Replies 21 ·
