Converting Proton Kenetic Energy to Electicity
  • Thread starter Thread starter MonroeIns
    Energy Proton
The discussion revolves around methods to convert the kinetic energy of moving protons or positively charged ions into electricity. Participants explore theoretical and practical aspects of this conversion, including electromagnetic fields, energy harvesting from charged particles, and applications in fusion reactors.
  • Experimental/applied
  • Some participants inquire about the electromagnetic fields generated by moving positively charged ions and whether energy can be harvested from them.
  • One participant suggests that any moving charge constitutes an electric current and discusses the conditions under which energy can be harvested from a stream of protons.
  • Another participant references a paper discussing alpha particles and their kinetic energy, proposing that deceleration with an electric field could produce current.
  • There are mentions of practical applications, such as using metal to collect charges from ions to generate electric current.
  • Some participants express interest in alternative methods for energy extraction from fusion reactors beyond traditional approaches like thermocouples.
  • One participant notes that while it is theoretically possible to generate electricity directly from alpha emitters, it is considered impractical compared to other methods.
  • There is a discussion about the feasibility and innovation in energy extraction methods, with some participants emphasizing the limitations imposed by reality.
Participants express a mix of agreement and disagreement regarding the methods and feasibility of converting kinetic energy from ions into electricity. While some acknowledge traditional methods, others seek innovative alternatives, leading to unresolved differences in approach and practicality.
Participants reference various theoretical concepts and practical applications, but there are limitations in the assumptions made about energy conversion efficiency and the specific conditions required for successful implementation.
This discussion may be of interest to those exploring energy conversion technologies, fusion reactor design, and the theoretical underpinnings of electromagnetic fields related to charged particles.
MonroeIns
Hello,
What methods are there to turn a moving proton or any positively charged ion into electricity. Does a positively charged ion, when moving, create an electromagnetic field like an electron will? If it moves through a negatively charged field of similar strength, slowing it down in effect, can that engergy be converted into electricity? Thanks!
MonroeIns said:
Hello,
For photons: photo-electric effect.
For +Q: any moving charge is an electric current already.
Yes
1. Electric fields don't have charge.
2. You generate energy from fields that accelerate the object - not slow it down.
Consider: do you get electricity from water by squirting it uphill or by letting it flow down-hill?
If you happen to know a beam of protons is passing by some place then you can harvest energy from it by putting something in the way to catch them. Normal conservation of momentum applies. However - the "something" will also get more and more positively charged. If you hook a wire from the ground to the "something" then electrons can flow from the ground attracted by the positive charge - presto: electric current.
Maybe I didn't ask the question correctly. I read this in a paper:
Alpha particles, which are helium atoms stripped of their two electrons, have a charge of +2. Each of the particles produced by this reaction has a kinetic energy of around 3 million electron volts. An electron volt is the energy a particle of charge 1 will pick up when accelerated through a field of 1 volt. The reverse is true, too. To slow down a 3 MeV particle with a charge of +2, simply decelerate it with a +1.5 million volt electric field. The particle will just kiss into the charged surface, and draw two electrons from it, producing current at high voltage.
This is what I am trying to better understand and see whether something similar is being used in any current applications.
I read this in a paper.
Which paper?
The quoted section basically says what I did.
This is what I am trying to better understand...
What is it you don't understand?
...and see whether something similar is being used in any current applications.
There are many applications using the phenomena mentioned.
I read it a paper describing how to build an amateur fuser. Can you read it here:
http://www.fusor.net/newbie/files/Ligon-QED-IE.pdf
Page 15 is where I got the quote from.
I have no plans to make a break even fusor, but I have bought all the parts to assemble a fusor, and I thought it would be interesting/challenging to pull electricity (as little as I may get from it) back out of the system. So, was pondering a design to do that.
I am trying to understand exactly how it would be done in application. If I had a stream of moving ions/helions, how to convert that to electricity.
Any advice? Thanks!
The simplest way to get energy from a stream of ions is to put a bit of metal in the way like I said. Ions hit the metal and make it charged. The charges make electrons in the metal move - that's an electric current.
The fusor's are intended to be fusion reactors - the energy output is supposed to be heat.
You would extract energy from a working fusor via a thermocouple or a steam engine... or something more exotic. AFAIK: all the effort is directed at getting one going.
Have you seen fusor.net?
Though you should be careful reading about fusors since there is a lot of rubbish around.
I understand that is the traditional way to get energy from a fusor, but I wanted to do something different, in the interest of science and fun. Yes, I have spent hours on that site.
Any other ideas?
I understand that is the traditional way to get energy from a fusor...
It is not a question of tradition - reality is dictating what is possible.
You can only get energy off what comes out of the fusor. There's not a lot of variation and I have already given you examples of each kind available. You should be able to go from there.
I wanted to do something different, ... Any other ideas?
Imagination and innovation is not cheap. If you'd prefer a rundown, in detail, of the technological options - I'll be happy to send you a schedule of my fees. Free ideas you'll have to come up with yourself. Sorry.
It has been done with alpha emitters, to produce electricity at a high voltage directly.
Very impractical though, so people use thermocouples to convert heat into electricity. One research project finally wants to build a real thermal engine around the radioactive source - but with pistons instead of turbines, stupids.
NTG's have been around for a while - and one of the earlier designs had a Stirling Engine (a heat engine with pistons) calling the designers "stupids" seems a bit harsh... you thinking of the ASRG?
