Volume Integration: Calculate Rotated Region Bounded by y=9-X^2, X=2
The problem involves calculating the volume generated by rotating a region bounded by the curve y = 9 - X^2, the line X = 2, and the x-axis around the y-axis. The subject area pertains to volume integration and the application of methods such as cylindrical shells.
  • The original poster attempts to integrate the volume for the region in both the first and second quadrants but is uncertain about how to set up the integration with respect to the y-axis due to the boundary at X = 2. Some participants suggest using the method of cylindrical shells and provide hints about the parameters involved, such as the height and radius of the shells.
Participants are exploring different interpretations of the problem, with some providing guidance on the cylindrical shells method. There is acknowledgment of a need to clarify the bounds of integration, particularly regarding the interval from 2 to 3.
There is a mention of potential confusion regarding the boundaries of the region, specifically the role of the line X = 2 and the limits of integration. The original poster expresses uncertainty about how to proceed with the integration setup.
Link
Calculate the volume generated when the region bounded by the curve y = 9 - X^2 , the line X = 2 and the x-axis is rotated 2pi about the y-axis.
For the part that lies in the second quadrant, i can integrate 9 to 0, then plug it into the volume formula. Then i have to add the volume of the part in the first quadrant. But since the X = 2 line slices a part of the area off i don't know how to integrate it respective to the y axis.
Try using the method of cylindrical shells which should be outlined in your book.
Graph the region that is described. This is simple to do,, draw a downward porabola with y intercept at y=9, and a vertical line at x=2. The region you want to consider is the region in the first quadrant that lies under the porabola and over the x-axis and between the lines x=2 and x=3.
hint:
the height of a shell will be 9 - x^2
the radius of the shell is x, so the circumference is 2(pi)x
the thickness of the shell is dx
you need to sum up all the shells with radius from x=2 to x=3
I hope I haven't given too much away.
Actually, you want the interval from 2 to 3.
The region would have to also be bounded by x=0 if you were going from 0 to 2.
Yes, thank you BobG! I overlooked that.
P.S. I will edit my post so as not to cause confusion.
  • · Replies 19 ·
