What is a typical constant for air resistance in relation to velocity?
Air resistance is a crucial factor in understanding the motion of objects through the atmosphere, particularly for a baseball at sea level. The drag force can be modeled using the equation D = 0.5 * C * A * ρ * v², where C is the drag coefficient, A is the cross-sectional area, ρ is the air density, and v is the velocity. For a spherical object like a baseball, the typical drag coefficient (C) is approximately 0.5. The constant k in the equation dV/dt = kv varies based on the object's shape and texture, making it essential to refer to established tables for accurate values.
  • Understanding of fluid dynamics principles
  • Familiarity with drag force equations
  • Knowledge of the drag coefficient and its significance
  • Basic physics concepts related to motion and forces
  • Research the effects of shape and texture on drag coefficients
  • Learn how to calculate the drag force for various objects
  • Explore the relationship between velocity and air resistance in different mediums
  • Investigate advanced fluid dynamics simulations using software like ANSYS Fluent
Physics students, engineers, and anyone interested in the dynamics of motion and air resistance, particularly in sports science and aerodynamics.
BigStelly
Hey I am just wondering about something, air Resistance is proportional to the velocity in some cases or velocity squared in others.
dV/dt=kv what is a typical constant for k, i know it varies so let's just say a baseball at sea level(im sure you all can guess why I am asking this... :smile: ) Also is there a way to calculate this "k"...
any help greatly appreciated thanks!
It depends very much on the shape and texture of objects, if you use the formula [tex]D = \frac{1}{2}CA\rho v^2[/tex]. For a spherical body like the baseball it should be around 0.5.
Have a look here also: http://www.ac.wwu.edu/~vawter/PhysicsNet/Topics/Dynamics/Forces/DragCoeficientValues.html for a table of constants.
