What is the force on an electron moving in a magnetic field?
The discussion revolves around the force experienced by an electron moving in a magnetic field, specifically involving the velocity of the electron and the magnetic field's components. The original poster presents their calculations and expresses uncertainty about the correctness of their approach, particularly regarding vector components and the application of relevant equations.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the use of the cross product to determine the force on the electron, with some questioning the original poster's method and suggesting a focus on vector components. There is uncertainty about whether the original equations provided are relevant to the problem at hand.
Some participants have offered guidance on using the correct formula for the force on a charged particle in a magnetic field, emphasizing the importance of the cross product. There is an ongoing exploration of the correct approach to the problem, with no clear consensus yet on the method to be used.
The original poster's calculations include various equations that may not apply directly to the question, leading to confusion about the relevance of certain components and the need for clarification on the use of vector operations.
airkapp
electrons and magnetism. - need help.
An electron moves with velocity v = (4.0i – 6.0ij) x 104 m/s in a magnetic field B= (-0.80i + 0.60j) T. Determine the magnitude and direction of the force on the electron.
F=ma: qvB=m*v^2/r : r= mv/qB
r = (9.1E^-31kg * (4.0i – 6.0ij) x 104 m/s) / (1.6E^-19 C * (-0.80i + 0.60j) T)
= (3.8E-28i + -5.7E-28j) / (-1.28E-19i + 9.6E-20j)T
= (-3E-9i - 5.9E-9j)T
qvB=m*v^2/r
= 9.1E^-31kg (3.8E-28i * -5.7E-28j)2 / (-3E-9i - 5.9E-9j)T
=(-4.44E-77i + 5.011E-77)T N southward.
I'm totally stuck on this problem. This is my work but I'm pretty sure it's wrong. I'm not sure how to handle the i, j, k component problems. or is this the way... take the i and j components of the velocity and the magnetic field, and find two separate force components, Fi and Fj. Then assume i and j are perpendicular vectors and then with Fi and Fj find the
magnitude of the force. Finally, find the angle in the i-j plane in this
way, knowing that the force would come into the k plane but not at a
right angle to both i and j?? is that correct?
thanks, any help would be appreciated.
Air K
I haven't even looked at your work, but the equation for the force of a point charge due to a magnetic field is:
[tex]\vec{F_B} = q\vec{v} \ X \ \vec{B}[/tex]
where "X" is the cross product.
You can calculate F in terms of components i, j, k. (do you know how to do cross product? )
Then finding the direction and magnitude of F can be done the same way you find the magnitude and direction of any vector.
The equations you gave are for the radius of an electron in uniform circular motion due to a magnetic field and are completely irrelevant to the question.
MathStudent said:
I haven't even looked at your work, but the equation for force is
hmm, I've done cross product before I'm just not sure if my method is right. I think I posted the same formula as you just did. Will my answer be in terms of I, J, K?
Don't I need to find "r" to solve the problem?
use this one
[tex]\vec{F}=q\vec{v}\times\vec{B}[/tex]
you have v and B already, don't over complicate the problem
do you know cross product?
hmm...why didnt I think of that :-p
  • · Replies 25 ·
