| Thread Closed |
Potential energy and a skateboard, only have until 11:30!!!! |
Share Thread | Thread Tools |
| Feb25-05, 08:48 PM | #1 |
A 54.5 kg. skateboarder starts out with a speed of 1.95 m/s. He does +80.0 J of work on himself by pushing with his feet against the ground. In addition, friction does -265 J of work on him. In both cases, the forces doing the work are nonconservative. The final speed of the skateboarder is 6.10 m/s
Calculate the change (PE = PEf - PE0) in the gravitational potential energy (b) How much has the vertical height of the skater changed? ok so potential energy is PE=MGH buti don't see a vertical height here! Please help!! |
| Feb25-05, 09:08 PM | #2 |
right...
You can define the height to be zero anwhere you like. I would suggest letting the height that he starts at be zero. Set up your Conservation of Energy equations (ME_i = ME_f, where ME = KE +PE) using variables for any unknowns. |
| Feb25-05, 09:14 PM | #3 |
Recognitions:
= 103.62 + PE0 {Final Total Energy} = (1/2)*m*vf^2 + PEf = (1/2)*(54.5)*(6.10)^2 + PEf = = 1013.97 + PEf {Delta Total Energy} = {1013.97 + PEf} - {103.62 + PE0} = = 910.35 + {Delta PE} = = {Work Performed On Subject} = (80) + (-265) = (-185) {Delta PE} = (-185) - (910.35) A) {Delta PE} = (-1095.35 J) m*g*{Delta H} = (-1095.35) {Delta H} = (-1095.35)/{(54.5)*(9.8)} B) {Delta H} = (-2.051 m) ~~ |
| Feb25-05, 09:49 PM | #4 |
here's what i did. plug all the numbers into Wnc= (1/2mvf^2-1/2mv0^2)+(mghf-mgh0) and you get Wnc= a number + a number *(h0-hf)
then you go and find Wnc first since it already told you in the question= +80-265 and you get -185. so -185=a number + a number *(h0-hf) and you can now find out what (h0-hf) equals to. which is close to 2. this is the answer to b (i got 2.15 cuz our variables are different on webassign) answer to a. since you know what h0-hf is. change in PE= mghf-mgh0 plug h0=hf+(your answer to B) and you get mghf-mghf-mg*(your answer to B) mghf cancels out. -mg*(your answer to B) is the answer for A (negative number) hope that helps......LOL |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Potential energy and a skateboard, only have until 11:30!!!!
| [SOLVED] Mechanical Energy vs Potential Energy & Kinetic Energy | Introductory Physics Homework | 3 | ||
| Print ViewElectric Potential Energy versus Electric Potential | Introductory Physics Homework | 2 | ||
| Electric potential, potential difference, and potential energy | Introductory Physics Homework | 2 | ||
| potential energy of a spring,POTENTIAL ENERGY OF LOADING | Classical Physics | 3 | ||
| Potential energy and a skateboard, only have until 11:30!!!! | Introductory Physics Homework | 1 | ||
