Another Question: Find the work done by the kinetic frictional force
The work done by the kinetic frictional force on a 90.0 kg refrigerator being pulled with a 300N force at an angle of 22.0° is calculated using the formula W = Fd cosθ. The coefficient of kinetic friction is 0.200, resulting in a kinetic frictional force of 176.4 N. The work done by this force over a distance of 6.00 m is -1058.4 J, indicating that the kinetic frictional force acts in the opposite direction of the refrigerator's movement. The total work done on the refrigerator, accounting for both the pulling force and kinetic friction, is 611.6 J.
  • Understanding of Newton's laws of motion
  • Familiarity with the concepts of force, work, and energy
  • Knowledge of the coefficient of kinetic friction
  • Ability to apply trigonometric functions in physics problems
  • Study the derivation and application of the work-energy principle
  • Learn about normal force calculations in various scenarios
  • Explore the implications of negative work in physics
  • Investigate the effects of different coefficients of friction on work done
Physics students, educators, and anyone interested in understanding the dynamics of friction and work in mechanical systems.
zizikaboo
A 300N force is pulling an 90.0 kg refrigerator across a horizontal surface. The force acts at an angle of 22.0° above the surface. The coefficient of kinetic friction is 0.200, and the refrigerator moves a distance of 6.00 m.
i found out the work done by pulling force is 1669 J and its asking for the work done by the kinetic frictional force!
here's what i did but the answer is wrong though...i tried a million times and it's still wrong! i know something's wrong here and i know it's not the acceleration of gravity or m...hmm
i did
mg times mu=9.8*90*.2
then i times it by the distance to get work. 176.4N*6m=1058.4 J
which is WRONG! arghh...am i missing something here? :smile:
i did
which is WRONG!
The friction is equal the normal force multiplied by the coefficient of friction.
[itex]F_{fr} = \mu F_N[/itex]
As the refrigerator slides on a horizontal plane the vertical component of the resultant force is zero. This vertical component is the normal force + vertical component of the pulling force - mg.
[itex]F_N+ F\sin (\alpha) - mg = 0[/itex].
ehild
The correct way to calculate the work done by the kinetic frictional force is to use the formula W = Fd cosθ, where W is the work done, F is the force, d is the distance, and θ is the angle between the force and the displacement.
In this case, the force acting against the movement of the refrigerator is the kinetic frictional force, which is given by Ff = μN, where μ is the coefficient of kinetic friction and N is the normal force. The normal force is equal to the weight of the refrigerator, so N = mg.
Plugging in the given values, we get Ff = (0.200)(90 kg)(9.8 m/s^2) = 176.4 N. Now, we can calculate the work done by the kinetic frictional force using the formula: W = Ff d cosθ = (176.4 N)(6.00 m)cos(180°) = -1058.4 J.
Note that the work done by the kinetic frictional force is negative because it is acting in the opposite direction of the displacement. This means that the kinetic frictional force is doing negative work, which is taking away energy from the system. Therefore, the total work done by all forces on the refrigerator is the sum of the work done by the pulling force (1669 J) and the work done by the kinetic frictional force (-1058.4 J), which is equal to 611.6 J.
