New Reply
Melting Ice in Seawater
Share Thread Thread Tools
Nov7-12, 03:16 PM   #1
Using a 30kg cubic block Ice at -20degC, I want to cool down a piece of steel which is resting on the seabed. The mass of steel is 1kg and the ice block is place on top of the steel.
The current sea temperature as well as the steel temp is estimated at 12degC
Assuming that the piece of steel is not "heated" by the seabed, nor the sea water, the ice melts while cooling the steel.
Question is till what temperature can the steel be cooled before the ice is completely melted and dissolved.
I'm kinda lost here on the thermodynamics, since the "energy out" does not equal the "energy in" as the unlimited amount of seawater volume will melt the ice without increasing in temperature.
can someone push me in the right direction please.
thanks
Patrick
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> New analysis yields improvements in a classic 3D imaging technique
>> Research effort deep underground could sort out cosmic-scale mysteries
Nov7-12, 03:44 PM   #2
I am afraid you cannot find the answer from pure energy balance.
The answer will depend on the rates of heat transfer from the water to the ice and steel to the ice.
There will be a temperature gradient building up around the ice block.
During melting you have a non-equilibrium situation. Water, ice and steel have different temperatures. I understand that you want to know what will be the temperature of the steel (assuming it is uniform, which may be a good approximation for a good conductor) at the very moment when the ice is completely melted.
So the answer will depend on the specific rates of heat transfer.
Unless you want to wait until equilibrium is reached again and then everything will be pretty much 12 degrees.
Nov7-12, 03:47 PM   #3
Recognitions:
Gold Membership Gold Member
I am looking for the 'nub' of this question. Is the fact that the ice and steel are on the sea bed relevant to the question? (You say the steel is not heated by the sea bed or the sea water).
New Reply
Thread Tools
Similar Threads for: Melting Ice in Seawater
Thread Forum Replies
What is the specific heat of seawater? Introductory Physics Homework 1
Electrolysis of Seawater under pressure General Physics 1
Jet nozzles effect in seawater General Engineering 5
Fluids -iceburg in seawater Introductory Physics Homework 2
Gold in seawater Chemistry 4
