Cauchy Sequences and Convergence
The discussion revolves around proving a theorem related to Cauchy sequences and convergence, specifically addressing the convergence of the sequence defined by the average of another convergent sequence.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants explore the relationship between the sequences (a_n) and (b_n), questioning how to demonstrate that (b_n) converges to the same limit as (a_n). Some suggest using the ε-N definition of convergence, while others express uncertainty about their reasoning and the validity of their approaches.
There is an ongoing exploration of different cases for the sequence (a_n), with participants attempting to establish mathematical arguments for convergence. Some guidance has been offered regarding the structure of the proof, particularly focusing on breaking down the argument into parts based on the ε-N definition.
Participants note the importance of rigor in mathematical proofs, particularly in relation to the definitions of convergence and the handling of sequences. There is an acknowledgment of the need for clarity in distinguishing between cases and ensuring that assumptions are properly justified.
Seth|MMORSE
Prove the following theorem, originally due to Cauchy. Suppose that [itex](a_{n})[/itex][itex]\rightarrow a[/itex]. Then the sequence [itex](b_{n})[/itex] defined by [itex]b_{n}=\frac{(a_{1}+a_{2}+...+a_{n})}{n}[/itex] is convergent and [itex](b_{n})[/itex][itex]\rightarrow a[/itex].
A sequence [itex](a_{n})[/itex] has the Cauchy property if, for each [itex]ε>0[/itex] there exists a natural number N such that [itex]|a_{n} - a_{m}|<ε[/itex] for all [itex]n,m>N[/itex]
I don't exactly know what am I suppose to do here ... ?
The only thing I could think of is [itex](a_{1}+a_{2}+...+a_{n})≈n*a_{n}[/itex] for a very huge n but that doesn't seem really relevant.
Am I suppose to show that [itex](b_{n})[/itex] is a subsequence? Or [itex](b_{n})[/itex] is somewhat related to the [itex](a_{m})[/itex] in the definition of the Cauchy sequence?
You know ##a_n\rightarrow a## and you want to make$$
\left| \frac{a_1+a_2+...+a_n}{n}-a\right |$$small if ##n## is large enough. Start with that.
Case 1: [itex](a_{n})[/itex] is an increasing sequence
[itex]\frac{(a_{1}+a_{2}+...+a_{n})}{n}-a<\frac{n*a}{n}-a=a-a=0<br /> \Rightarrow b_{n}-a<0[/itex]
Case 2: [itex](a_{n})[/itex] is a decreasing sequence
[itex]\frac{(a_{1}+a_{2}+...+a_{n})}{n}-a>\frac{n*a}{n}-a=a-a=0<br /> \Rightarrow b_{n}-a>0[/itex]
[itex]\Rightarrow 0<b_{n}-a<0 <br /> <br /> \Rightarrow |b_{n}-a|<0<br /> <br /> \Rightarrow b_{n}\rightarrow a[/itex]
Does this make any sense?
I'm afraid not. The sequence can't be both increasing and decreasing unless it is a constant, and it may not be either one anyway. I would try to find an ##\epsilon,\, N## type of argument.
I have to leave for a couple of hours. Let me just add not to waste your time using the Cauchy criteria. All you need is the ##\epsilon,\, N## definition of ##a_n\rightarrow a##.
Okay, thanks! Will try ...
[itex]a_{n}\rightarrow a \Rightarrow |a_{n}-a|<\epsilon, \forall n>N[/itex]
Assume [itex]|\frac{(a_{1}+a_{2}+...+a_{n})}{n}-a|<2\epsilon[/itex]
[itex]|\frac{(a_{1}+a_{2}+...+a_{n})}{n}-a-(a_{n}-a)| \leq |\frac{(a_{1}+a_{2}+...+a_{n})}{n}-a|-|a_{n}-a| < 2\epsilon-\epsilon[/itex]
[itex]\Rightarrow |\frac{(a_{1}+a_{2}+...+a_{n})}{n}-a_{n}|<\epsilon[/itex]
Okay I honestly have no idea where am I going with this. :cry:
Seth|MMORSE said:
[itex]a_{n}\rightarrow a[/itex] means that
Given ##\epsilon > 0## there exists ##N## such that
[itex]|a_{n}-a|<\epsilon, \forall n>N[/itex]
If you are going to do an ##\epsilon,\, N## proof, it is best to give complete and exact statements. And it might be a good idea to use ##\epsilon/2## or ##\epsilon/4## to give yourself some extra room.
But that is basically what you are trying to prove. You can't start by assuming it is true.
Yes, I see that. As I said earlier, you want to start with $$
and make it small. To get started write it as a single fraction$$
\left| \frac{a_1+a_2+...+a_n-na}{n}\right |$$Now since, at least for large ##n##, you can make ##|a_n-a|## small, try spreading the n a's with each of the ##a_i##'s. Then think about the part where ##n\le N## and where ##n>N## and see if you can make them both small for ##n## large enough.
Hmm ... guess I should refrain from rephrasing definitions so carelessly.
##|b_{n}-a|=|\frac{(a_{1}+a_{2}+...+a_{n})}{n}-a|##
##=|\frac{(a_{1}+a_{2}+...+a_{n})-na}{n}|##
##=|\frac{((a_{1}-a)+(a_{2}-a)+...+(a_{n}-a))}{n}|##
##\leq |\frac{(a_1-a)}{n}|+|\frac{(a_2-a)}{n}|+...+|\frac{(a_n-a)}{n}|## [by Triangle Inequality]
[itex]<\frac{\epsilon_1}{n}+\frac{\epsilon_2}{n}+...+[/itex][itex]\frac{\epsilon_{n}}{n}[/itex] [Since ##|a_n-a|<\epsilon## and the theorem that states that subsequences (i.e. ##a_1, a_2, ...##) tend to the same limit (single term subsequences as well??)]
##=\frac{n\epsilon}{n}##
##=\epsilon##
[itex]\Rightarrow |b_{n}-a|<\epsilon[/itex]
Obviously missing out on something (or totally off track?) since there was nothing relevant to your last sentence. I understand that by definition of convergent sequences, it will only be between both ##\epsilon## if ##n## is larger than a specific point ##N## that corresponds to the ##\epsilon## chosen but ... then what?
I feel very bad for having the lack of capability to comprehend your hints ...
OK so far. Just do what I suggested. If ##n>N## part of that sum has ##n\le N## and part has ##n>N##. Break it into those two parts. Then what you have to figure out is why both parts are small if ##n## is large enough (and how large "large enough" is). That is the meat of the argument.
I guess for ##n\le N##, this part would be small enough because of a large denominator, i.e. ##n##? Whereas for ##n>N, (a_n-a)## would be small ... but I'm pretty sure this isn't what you're alluding to ...
I don't get it :confused:
What end result am I looking for? Something like the one I posted before but with different intermediate steps?
That is the idea but you must write it mathematically. And you haven't yet broken it into two parts depending on ##N##. You are going to need an ##N## in there do do that. Then show how big and why that big that ##n## must be to make each of those less than ##\epsilon/2## to get the whole thing less than ##\epsilon##.
What are you looking for?? If you don't know that no wonder you are confused. Read your statement in red above. And ##b_n\rightarrow a## means given ##\epsilon > 0## blah blah. You really need to learn carefully to write down what you are given and what you are trying to prove, using the definitions.
Something like this??
##|\frac{(a_1-a)}{n}|+|\frac{(a_2-a)}{n}|+...+|\frac{(a_N-a)}{n}|+|\frac{(a_{N+1}-a)}{n}|+...+|\frac{(a_n-a)}{n}|##
##(|\frac{(a_1-a)}{n}|+...+|\frac{(a_N-a)}{n}|)+(|\frac{(a_{N+1}-a)}{n}|+...+|\frac{(a_n-a)}{n}|)##
To clarify, I wasn't unsure of the main objective of the question, just wanted to know whether am I suppose to get something something ##<\epsilon##, to which you have answered.
That's better. Now look again at the advice from post #6 I have highlighted above.
Only thing I could come up with is this:
##(|\frac{(a_1-a)}{n}|+...+|\frac{(a_N-a)}{n}|)<\frac{|a_n-a|}{2}<\frac{\epsilon}{2}##
##\frac{N(a_N-a)}{n}<\frac{|a_n-a|}{2}##
##\frac{N}{n}<\frac{1}{2}##
##n>2N##
Okay, thought about it again (okay not really, kinda discussed with my friends) and this is the result.
Let ##\epsilon>0, |a_n-a|<\frac{\epsilon}{2} \ \forall n>N##
##|\frac{a_{N+1}-a}{n}|+...+|\frac{a_{n}-a}{n}|<\frac{\epsilon_{N+1}}{2n}+...+\frac{ε_{n}}{2n}=(\frac{n-N}{n})(\frac{\epsilon}{2})##
Since ##n>N, (\frac{n-N}{n})<1##
##\Rightarrow|\frac{a_{N+1}-a}{n}|+...+|\frac{a_{n}-a}{n}|<\frac{\epsilon}{2}##
For the remaining part ...
##|\frac{a_{1}-a}{n}|+...+|\frac{a_{N}-a}{n}|=\frac{1}{n}(|a_1-a|+...+|a_N-a|)##
##(|a_1-a|+...+|a_N-a|)## is already fixed, therefore for a large enough ##n, \frac{1}{n}(|a_1-a|+...+|a_N-a|)<\frac{\epsilon}{2}##
I still don't see how can I show how big of an ##n## is required ...
Solve that inequality for n to see how large it must be.
##\frac{1}{n}(|a_1-a|+...+|a_N-a|)<\frac{\epsilon}{2}## this?
##\frac{2(|a_1-a|+...+|a_N-a|)}{\epsilon}<n##
I didn't notice when I scanned your post a minute ago. Where did all these ##\epsilon_n##'s come from? You can't introduce new variables in a proof without saying what they represent.
Oh, they're just ##\epsilon##'s that correspond to each term ... which are essentially the usual ##\epsilon##'s. Sorry about that.
OK, after all this discussion, let's see a complete, properly written argument, starting with what you are given, what you have to show and showing it.
Suppose ##(a_n)\rightarrow a##.
Show that ##(b_n)\rightarrow a## when ##b_n=\frac{a_1+a_2+...+a_n}{n}##
Definition of ##(a_n)\rightarrow a##:
For each ##\epsilon>0, \exists n\in \mathbb{N}:|a_n-a|<\epsilon\ \forall n>N##
Let ##|a_n-a|<\frac{\epsilon}{2}\ \forall n>N_0##
Show ##|b_n-a|<\epsilon##
##|b_n-a|##
##= |\frac{a_1+a_2+...+a_n}{n}-a|##
##=|\frac{a_1+a_2+...+a_n-na}{n}|##
##=|\frac{(a_1-a)+(a_2-a)+...+(a_n-1)}{n}|##
By triangle inequality,
##\leq |\frac{a_1-a}{n}|+|\frac{a_2-a}{n}|+...+|\frac{a_n-a}{n}|##
##=\underbrace{(|\frac{a_1-a}{n}|+...+|\frac{a_{N_0}-a}{n}|)}_{p}+
\underbrace{(|\frac{a_{N_0+1}-a}{n}|+...+|\frac{a_n-a}{n}|)}_{q}##
##p=|\frac{a_1-a}{n}|+...+|\frac{a_{N_0}-a}{n}|##
##=\frac{1}{n}(|\frac{a_1-a}{n}|+...+|\frac{a_{N_0}-a}{n}|)##
We define ##n>\frac{2|\frac{a_1-a}{n}|+...+|\frac{a_{N_0}-a}{n}|}{\epsilon}##
##\frac{1}{n}(|\frac{a_1-a}{n}|+...+|\frac{a_{N_0}-a}{n}|)<\frac{\epsilon}{2}##
##\Rightarrow p<\frac{\epsilon}{2}##
##q=|\frac{a_{N_0+1}-a}{n}|+...+|\frac{a_n-a}{n}|##
Using ##|a_n-a|<\frac{\epsilon}{2}\ \forall n>N_0##
##q<\frac{\epsilon/2}{n}+...+\frac{\epsilon/2}{n}##
##=(\frac{n-N_0}{n})(\frac{\epsilon}{2})##
##=(1-\frac{N_0}{n})(\frac{\epsilon}{2}##
Since ##n>N_0, (1-\frac{N_0}{n})<1##
##(1-\frac{N_0}{n})(\frac{\epsilon}{2})<\frac{\epsilon}{2}##
##\Rightarrow q<\frac{\epsilon}{2}##
##|b_n-a|=p+q##
##|b_n-a|< \frac{\epsilon}{2}+\frac{\epsilon}{2}=\epsilon##
##∴(b_n)\rightarrow a##
You have there exists n, then you mention N, then you mention ##N_0## below, but you haven't told us what ##N## or ##N_0## is. I suppose you meant this: For each ##\epsilon>0, \exists N\in \mathbb{N}:|a_n-a|<\epsilon\ \forall n>N##
You mean there exists ##N_0## such that ##|a_n-a|<\frac{\epsilon}{2}\ \forall n>N_0##. But you don't need another N. Just use ##\epsilon/2## in the first place: For each ##\epsilon>0, \exists N\in \mathbb{N}:|a_n-a|<\epsilon/2\ \forall n>N##
NO! You must show there exists an ##M## such that if ##n>M## then ##|b_n-a|<\epsilon##. Definitions, definitions! Everything below is dedicated to finding such an ##M##, isn't it? And you can use ##N## instead of ##N_0## below as I indicated above.
##|b_n-a|##
Check your arithmetic there and fix the 3 lines below.
##|b_n-a|=p+q##
You aren't done until you give me the value of ##M## that works. One more iteration should fix your argument.
You mean there exists ##N_0## such that ##|a_n-a|<\frac{\epsilon}{2}\ \forall n>N_0##. But you don't need another N. Just use ##\epsilon/2## in the first place: For each ##\epsilon>0, \exists N \in \mathbb{N}:|a_n-a|<\epsilon/2\ \forall n>N##
For each ##\epsilon>0, \exists N\in \mathbb{N}:|a_n-a|<\frac{\epsilon}{2} \forall n>N##
Show ##\exists M\in \mathbb{N}:|b_n-a|<\epsilon\ \forall n>M##
##|b_n-a|##
##=\underbrace{(|\frac{a_1-a}{n}|+...+|\frac{a_{N}-a}{n}|)}_{p}+
\underbrace{(|\frac{a_{N+1}-a}{n}|+...+|\frac{a_n-a}{n}|)}_{q}##
##p=|\frac{a_1-a}{n}|+...+|\frac{a_{N}-a}{n}|##
##=\frac{1}{n}(|a_1-a|+...+|a_{N}-a|)##
We define ##n>\frac{2(|a_1-a|+...+|a_{N}-a|)}{\epsilon}##
##\frac{1}{n}(|a_1-a|+...+|a_{N}-a|)<\frac{\epsilon}{2}##
##q=|\frac{a_{N+1}-a}{n}|+...+|\frac{a_n-a}{n}|##
Using ##|a_n-a|<\frac{\epsilon}{2}\ \forall n>N##
##=(\frac{n-N}{n})(\frac{\epsilon}{2})##
##=(1-\frac{N}{n})(\frac{\epsilon}{2})##
Since ##n>N, (1-\frac{N}{n})<1##
##(1-\frac{N}{n})(\frac{\epsilon}{2})<\frac{\epsilon}{2}##
##|b_n-a|=p+q##
##M=N?##
##∴\exists M:|b_n-a|<\epsilon\ \forall n>M##
Okay ... I guess I have to work on using definitions properly ...
##|b_n-a|##
Much clearer to let ##N_1=\frac{2(|a_1-a|+...+|a_{N}-a|)}{\epsilon}## and say if ##n>N_1## then ##p<\frac{\epsilon}{2}##
##|b_n-a|=p+q##
Shouldn't that be ##\le##?
##M=N?##
No. You don't get to just pull that out of a hat like magic. Look at the argument and figure out how big M has to be to make it all work.
Does it have anything to do with the fact that I used ##N## for the first sequence and I used ##\frac{\epsilon}{2}## as a bound?
Only in the fact that if both pieces are less than ##\frac{\epsilon}{2}## their sum will be less than ##\epsilon##. How big does ##n## have to be to get both parts to work?
Like the one stated in the workings? ##n>## than something for the first section and just ##>N## for the second one.
I can visualise ##a_n## eventually lying within ##\epsilon/2##'s after ##N##, but how would I know where M would be for ##b_n##?
We have already talked about that. Look back and absorb what we have talked about.
##M>N_1## that you defined? I have the feeling that I have to start learning analysis from scratch again ...
  • · Replies 28 ·
